Results 1 to 5 of 5
Thread: Micro Four Thirds Lens on Four Thirds Camera
    Porky4
    Question Micro Four Thirds Lens on Four Thirds Camera
    Hi folks,
    Sorry if this is a real numbty-type question, but I couln't find the answer anywhere via Google (probably asking the wrong questions!). I have a Panasonic G1 and the excellent Panasonic 20mm F1.7 lens. I may also be getting an Olympus Four Thirds camera and abviously would like to use the "pancake" on that. So the question is "can you"? I know it is possible to use Four Thirds lenses on Micro Four Thirds cameras via the MA1 (?) adapter, but is there a Micro Four Thirds to Four Thirds adapter?
    Paul
    Jan 2010
    Breckerfeld, Germany
    82
    4
    Re: Micro Four Thirds Lens on Four Thirds Camera
    No chance - the distance from lens to sensor is smaller on Micro 4/3 than 4/3. So mounting a 4/3 lens on Micro 4/3 is no problem, just add an adapter to add some distance. But the other way around does not work, the lens would need to sit inside the body...
    Andreas
    Porky4
    Quote Originally Posted by Schmiddi View Post
    Andreas
    Thanks Andreas, I thought that would be the case, but I had to ask ...
    I think I'll keep the G1 just for the 20mm F1.7!
    Paul
    Jun 2009
    San Diego, CA
    776
    You could certainly mount anything to anything else given enough creativity in building the appropriate adapter. You'd be able to use your MFT lenses on your 4/3 camera, but only for macro work since you'd lose infinity. You'd also have to set your aperture on your MFT camera first, then attach the MFT lens to your 4/3 camera.
    I'd say it's possible, but I'm guessing not worth it.
    -Dragos
    Panasonic GH1/G1, Canon FTb(n)/F-1, Mamiya C330F/RB67 Pro SD, Chamonix 45N-2, Nikon F5 + Assorted Lenses
    Senior Member biglouis's Avatar
    May 2009
    2,120
    I appreciate the question because the 20/1.7 is a fantastic lens. If I was making the commitment to a 4/3rds camera I might think about trying to obtain the Leica 25/1.4 as my prime lens.
    LouisB
