Results 1 to 13 of 13
Thread: Is it impossible to get good jpegs from G1/GF1?
    Feb 2008
    Florida
    392
    Is Panasonic jpeg engine on G1/GF1 really as bad as perceived on the internet forums? If yes, is there a way to get decent jpegs through custom settings?
    I do use RAW but taking even casual snaps in RAW would be bit too much for me. So looking for feedback/suggestions.
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,930
    Re: Is it impossible to get good jpegs from G1/GF1?
    Quote Originally Posted by sagar View Post
    Of course it is possible to get excellent JPEGs from these cameras.
    Experiment until you learn what settings do what you like. That's all.
    Kiri
    I wouldn't say they are bad. Its just that a lot of people compare them to the olympus ones, which are very highly regarded.
    Nov 2009
    Trondheim, Norway
    110
    I had a G1 and my biggest problem was white balance. It often made the colors too blue and magenta for my taste.
    You can tweak the White Balance settings in the camera though. I made mine more green (=less red/magenta) and more yellow (=less blue/warmer). To put the camera on "Cloudy" white balance helps too. This worked pretty well most of the time, but sometimes the colors still were completely wrong and had to be changed afterwards. After a few months I got tired of it and sold the camera.
    I should add that I'm very picky with colors, maybe more than most other people, because I'm an artist/illustrator and work with colors all day long.
    With RAW it's not a problem, but I didn't want to do RAW with this camera since it was supposed to be my "snapshot" camera.
    Terry's Avatar
    New York City
    6,955
    1145
    As said the colors can be tweaked to taste in camera but don't overlook B&W.
    Panasonic's Dynamic B&W setting is superb and a lot of times I can't improve upon the jpegs.
    Senior Member Y.B.Hudson III's Avatar
    Jan 2008
    314
    yehh...my EPL-1 jpgs [email protected] everything look like a happy daze in Hawaii; and the file it generates to do that is larger than the concurrent raw data. Everyone knows a purple iris is more pleasing to the eye when rendered in cerulean blue...
    taphapy
    I have a little problem with purple (too much red) but that's all I can see. That doesn't mean there's not other problems, just that I haven't noticed!
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    If the EPL-1 shows purple color, consider it a cheaper alternate to the Leica M8 (G1 is not useful for IR).
    May be it will be useful for IR?
    On the original question- as noted by others before, I suppose, it is possible to to play around with the many variables the cams offer to produce what would be acceptable. This also gives you a chance to familiarize yourself with the camera menus.
    May 2009
    Southport, Australia
    1,429
    I believe little of the stuff that passes for information on some of the "foaming at the mouth" forums. I don't like AWB, and thus balance myself ... having said that even shooting in AWB and doing mild tweaks in photoshop won't cause posterisation that will be observable.
    let me ask you a question ... are you unhappy with the JPG's from your G1/GF1?
    This set
    http://www.flickr.com/photos/pellicl...7623003446585/
    are all JPG sourced
    Jan 2009
    College Place, WA.
    790
    I shoot jpg all the time unless I'm shooting indoor sports under cycling lights. Then I shoot raw. I prefer the colors out of camera from my GF1 compared to my Nikon D2Hs. I like the jpgs from the GF1 and until now haven't seen a reason to switch to raw.
    Senior Member RichA's Avatar
    Jul 2009
    544
    Get Lightroom and leave inferior JPEGs behind forever. Use raw exclusively.
    May 2009
    1,429
    Hi
    I notice that despite your provocative title, and follow through with:
    despite me providing some answers to your question, you still have not addressed my question of:
    nor provided any further specifics on what it is (apart from your readings of the "forums") which makes it impossible to get good JPG's from the camera?
    was it a genuine question, do you yourself have any issues with the JPG's from the camera or was it just a quick stir of the pot?
    Los Altos, CA
    10,486
    1031
    I have both my regular GF1 and IR GF1 set to capture both RAW and jpeg simultaneously. Often I just grab an in-camera jpeg and dowrez it for posting in the forum threads. Of course if we're sharing prints at the quarterly local GetDPI get-togethers, then I'll work up the raw for print
    home: www.getdpi.com
