Results 1 to 7 of 7
Thread: Leica M/MFT question
    Mar 2008
    70
    I have just bought a Voigtlander Leica M/MFT adapter and would like to try my WATE with it. However no Leica lenses are listed on the compatability list which came with the adapter and I am concerned it may get damaged if I try it
    Does anyone know whether it is safe to use with an MFT adapter?
    seakayaker's Avatar
    Apr 2010
    Seattle, WA
    2,889
    Re: Leica M/MFT question
    Quote Originally Posted by daveproctor View Post
    I believe the Wate is a screw mount. If it is you will need the 'Screw' mount adaptor. It is a $57.00 item that you can get from Camerquest or other Voigtlander supplier.
    Information can be found at: http://www.cameraquest.com/adaptltm.htm
    The metal ring fits into the M/MFT Voigtlander adaptor. The combination of the two allows you to use 'M' mounts and 'Screw' mounts with the micro 4/3 camera.
    You can also get a direct Screw Mount adaptor to Micro four thirds. I believe Novaflex sells one.
    Life is Grand!
    Dan
    Mar 2008
    70
    Never seen a screw mount WATE! Mine is definitely M-mount
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,601
    21
    Here: http://forum.getdpi.com/forum/showthread.php?t=5311
    Dan, WATE is not screw mount.
    seakayaker's Avatar
    Apr 2010
    Seattle, WA
    2,889
    If it is a M mount then the M/MFT Voigtlander adaptor should work.
    The above adaptor is what I use for my Voigtlander/Leica"M" lens to my GF1.
    Life is Grand!
    Dan
    seakayaker's Avatar
    Apr 2010
    Seattle, WA
    2,889
    . . . . thanks!
    Life is Grand!
    Dan
    Mar 2008
    70
    Thanks guys - looks like is safe to try.
    I was concerned that some lenses extend too far back and there is a potential problem due to this where the lens could be damaged
