Results 1 to 5 of 5
Thread: Canon FD body to Eos Lens Adapter
    Jan 2010
    26
    Does anyone know if such an adapter is possible or exists? I am posting in this section as it would be to go on a GH1 FD adapter and for experiments with m43rds. If it is possible does anyone know someone that can make them? Many thanks.
    Jun 2009
    San Diego, CA
    776
    Re: Canon FD body to Eos Lens Adapter
    There are FD-to-Eos adapters out there, but not the other way around. Eos has a slightly shorter registration distance than FD, so Eos lenses on an FD body wouldn't work other than in macro mode. Why not just get an Eos-to-MFT adapter if you want to play with Eos lenses on your GH1? You won't be able to adjust aperture, but at least you can get your Eos lenses on.
    -Dragos
    Panasonic GH1/G1, Canon FTb(n)/F-1, Mamiya C330F/RB67 Pro SD, Chamonix 45N-2, Nikon F5 + Assorted Lenses
    Jan 2010
    26
    I thought FD was shorter. On wikipedia it states reg dist 42mm for FD and 44mm for EOS. Would that make it possible? Like you can use a Olympus lens (46mm) on a Canon EOS body (44mm).
    Jun 2009
    San Diego, CA
    776
    Quote Originally Posted by kainekainekaine View Post
    Yes, sorry, typo. People convert their FD lenses to fit on Eos camera by replacing the mount to shave off those 2mm extra, than in many cases have to shave off pieces of the rear element to clear the mirror. It's possible to make an Eos mount for FD cameras I suppose, but I don't know if anyone has. In any case, why go through all that when you can mount both of those directly to your GH1?
    -Dragos
    Jan 2010
    17
    It would be much more efficient to purchase an EOS to m43 adapter, rather than spending the same money on an adapter that would then mount on another adapter.
    Just a suggestion:
    Canon EOS to m43: This adapter has a built in tripod mount and also can function as a shift mount for seamless stitching! Cheaper ones can be had but without the mount. I have the Leica R to m43 version and it is very well made.
    http://www.amazon.com/Fotodiox-Adapt...119013&sr=8-22
    Best regards,
    Jonathan
