Results 1 to 7 of 7
Thread: 8mm cine lens.
    Nov 2010
    15
    8mm cine lens.
    I am still new to using cine lenses on G1. Just wondering if the sensor coverage for using an 8mm lens is too narrow. For example this one:
    http://cgi.ebay.at/YASHICA-Cine-YASH...item43a2a76899
    What is the difference between a c-mount and d-mount lens? How do you figure the equivalent 35mm focal length when you a cine lens on the G1? Does the FOV changes as well relatively speaking?
    Thanks!
    Senior Member kds315's Avatar
    Sep 2009
    Weinheim, Germany
    1,442
    Re: 8mm cine lens.
    google? wikipedia? It's all there - just a few clicks, so easy...
    Jun 2010
    110
    Re: 8mm cine lens.
    So easy......
    Nov 2010
    15
    Re: 8mm cine lens.
    I was hoping some of the cine lens GURU out there would share their knowledge with me. Never mind, google it is then...
    Aug 2009
    Sydney, Australia
    347
    Re: 8mm cine lens.
    D mount lenses mount far too closely to the sensor to be used for anything other than extreme macro. The coverage won't come anywhee near filling a frame. Most 16mm lens don't.
    Nov 2010
    15
    Re: 8mm cine lens.
    How does c-mount lenses relate to 35mm lenses in terms of their FOV when mounted on the G1? Because of the smaller circle of confusion with cine lenses, does it means the resolution or bokeh would be better? I know spherical aberrations are generally not well corrected with cine lenses on G1
    Nov 2010
    15
    Re: 8mm cine lens.
