Results 1 to 4 of 4
Thread: CV 50.1.1 vs. 1.5
    Aug 2009
    724
    CV 50.1.1 vs. 1.5
    Did anybody do side by side comparison of output at same apertures? Thank you!
    Senior Member biglouis's Avatar
    May 2009
    2,120
    Re: CV 50.1.1 vs. 1.5
    Quote Originally Posted by ZoranC View Post
    No, but I have owned both. I kept the Nokton 1.5 over the 1.1 if that tells you anything. I liked the 1.1 but my copy was awfully soft wide open and I gradually began to resent that fact. My Nokton 1.5 is also soft wide open (to be expected, btw) but its performance at f2 and above is just spectacular (as is the 1.1) but at a much lower cost.
    LouisB
    Gothenburg, Sweden
    1,309
    But how soft is "soft wide open" Louis?
    I have a CV50/1.5. When comparing it, the resolution in this case, to a Zeiss Contax Planar 50/1.7 they are nearly impossible to tell apart. The Planar 50/1.7 is generally considered to be very sharp wide open.
    /Jonas
    Aug 2009
    724
    Quote Originally Posted by biglouis View Post
    LouisB
    Louis, thank you for your vauable input. How they compared when 1.1 was at 1.4 and 1.5 was at 1.5? What about same but at 1.8? Was performance past 2 identical, where one could not be able to tell them apart, or there was still some difference and if yes where? Thank you again!
