Results 1 to 11 of 11
Thread: GH2 4/3 adapter question
    Senior Member peterb's Avatar
    Tysons Corner, Virginia
    490
    18
    I have the G1 and if I were to use the 4/3's adapter for use with Olympus high grade and super high grade optics it would be manual focus only.
    Now apparently, the GH2 (as well as most other models AFTER the G1) can be used in AF (single not continuous) with most of these superb lenses using the adapter. (I think the 150mm f2.0 prime is still the only 4/3 optic that's still MF only but most of the others apparently allow AFS with the adapter.)
    I'm particularly interested in the GH2 now as a MAJOR improvement with its new image processor, faster AF and huge jump in sensor size.
    Could anyone who has the GH2 and the 4/3's adapter tell me how well or how fast (if at all) Zuiko 4/3's HG and SHG lenses focus on it.
    While I'm sure the performance isn't speedy is it okay? Or, is it dog-days-in-August slow?
    Just need to get an idea. Thanks.
    Life is an infinite series of moments called..."now".
    My job is to capture them.
    May 2009
    Southport, Australia
    1,429
    Re: GH2 4/3 adapter question
    Quote Originally Posted by peterb View Post
    ... and huge jump in sensor size.
    are they not still making the G2 as micro 4/3? Have not read of the increase in sensor size
    would be pleased however to get better AF from Olympus lenses :-)
    Happy New Year to everyone
    Jan 2010
    West Chester, PA
    199
    Quote Originally Posted by pellicle View Post
    Yes, they are still making the G2, G10 and GF1. Those are all 12 megapixel sensors. The GH2 is the replacement for the GH1, and has the new 16 megapixel image size (like the GH1 the sensor is larger so other image sizes are not crops).
    Nov 2009
    Hawaii
    944
    16
    Peter -
    I am using the Olympus 11-22mm f/2.8-3.5 ZD on the GH2 with the Panasonic adapter. It is slow.....not like cold molasses, but slow. (I don't really care that much about focus speed since I use it mostly for landscape. It has good optics and I can hang my ND filters off the front.)
    The focus is very accurate and it doesn't rack and hunt.....even in low light. It makes the 12-60 start to look very appealing.
    Hope this helps.
    R
    May 2009
    1,429
    Quote Originally Posted by CPWarner View Post
    Not sure I understand what you mean here, but if you're referring to the 16:9 taking advantage of the extra width of the sensor. I understand (from files given to me from GH1 usersthat the native area of a GH1 is 4018 x 3016 pixels, while the native area of a G1 is exactly the same.
    While people think that the G1 only has 4000 pixels of width, when using other software (such as dcraw) you can get at the small extra width of 4018 pixels which is normally used for image corrections.
    Either way I don't think you'll find that the extra size is anywhere near as substantial as the move up to APS-C which defenders of 4/3 will not normally say is a "huge jump in size"
    Unless going up in megapixel count is the huge jump in size that the OP was talking about. On that topic I'm moot ... I'll need to see if the extra pixels come at a cost of noise in high ISO
    This article seems to show
    Jun 2009
    San Diego, CA
    776
    Not quite. One of the significant advantages of using a GHx series over any other m4/3 body is the fact that the GH bodies use a much larger sensor in order to maintain a constant angle-of-view. Here's the resolution of the different GH bodies in different aspect modes (as you can see it's significantly different than the 4018x3016 you mentioned - whoever gave you those files was only shooting in 4:3 aspect ratio, which doesn't highlight the full capability of the sensor):
    GH1:
    4000 x 3000 (4:3)
    4128 x 2752 (3:2)
    4352 x 2448 (16:9)
    GH2:
    4608 x 3456 (4:3)
    4752 x 3168 (3:2)
    4976 x 2800 (16:9)
    G1/G2/GF1 (etc.):
    4000 x 3000 (4:3)
    4000 x 2672 (3:2)
    4000 x 2248 (16:9)
    This means that a 14mm lens on a GH1, for example, has the equivalent horizontal FOV of roughly a 12mm lens in 16:9 mode. Very useful feature in shooting wide angle lenses with these bodies, which is normally a limitation for small sensors like these.
    -Dragos
    Panasonic GH1/G1, Canon FTb(n)/F-1, Mamiya C330F/RB67 Pro SD, Chamonix 45N-2, Nikon F5 + Assorted Lenses
    Senior Member biglouis's Avatar
    May 2009
    2,122
    Quote Originally Posted by photoSmart42 View Post
    GH2:
    4608 x 3456 (4:3)
    4752 x 3168 (3:2)
    4976 x 2800 (16:9)
    Dragos
    Thanks for explaining this. Makes it a lot clearer than I previously understood.
    Does the choice of aspect ratio affect the signal to noise ratio of the sensor, e.g. would you expect the same high iso performance at all aspect ratios?
    LouisB
    May 2009
    1,429
    Hi Dragos
    GH1:
    4000 x 3000 (4:3)
    4128 x 2752 (3:2)
    4352 x 2448 (16:9)
    those numbers are interesting. I have in the past looked for the measurements of the 16:9 mode on the GH1 and not found much information on it. It seems that (based on those dimensions) the sensor may approach the width of APS-C sensors. Interesting
    Still ... in my vocab that's not "huge" ... like say a 36mm sensor width.
    others may of course speak differently on the topic.
    I just wish I could get a full frame 35mm sensor in a camera the size and weight of the G1, even at 12 Megapixels (I have this 21mm lens I really like on full frame ;-)
    thanks for the input
    Jun 2009
    San Diego, CA
    776
    Quote Originally Posted by biglouis View Post
    Dragos
    LouisB
    No, there's no difference I know of regarding different SNR at different aspect ratios. Basically the processor is simply using different portions of the over-size sensor, which is why the GH sensors are physically larger (18 x 13.5mm) than the normal 4/3 sensors (17.3 x 13.0mm), and come in slightly closer to APS-C size (22.7 x 15.1 mm).
    Panasonic's LUMIX website explains it pretty clearly here if you're interested in the details: http://panasonic.net/avc/lumix/syste...igh_speed.html
    -Dragos
    Jun 2009
    San Diego, CA
    776
    I'd be happy with an APS-C or m4/3 sensor in a body as weather-sealed like the K-5, frankly, but I hear what you're saying. =)
    -Dragos
    May 2009
    1,429
    ok ... so two models, the APS-C and the full frame version in a weather sealed body with an EVF like the G[H]1 and a flange distance to allow all manner of mounts.
    Preferably it also comes with a carton of beer to make reading the manual more interesting.
