Results 1 to 10 of 10
Thread: Panasonic GH2 focus assist
    Jun 2009
    Vienna, Austria
    145
    a question to GH2 users:
    Can you invoke focus assist/magnification when using non-AF lenses (e.g. old Zuiko lenses via an OM adapter)? how do you invoke it?
    And: does focus assist/magnification only work on the backscreen, or also in the electronic viewfinder?
    I appreciate your comments,
    geb
    Gothenburg, Sweden
    1,309
    Re: Panasonic GH2 focus assist
    Without having tried a GH2 I can describe how to do it with a G1:
    Yes it is possible, you press left arrow and then the center button. Now the image is enlarged 7x. You can go to 14x by turning the control dial one step. You go back to normal view by pressing the shutter button half way down.
    It is the same for all other Panasonic cameras except that you don't need to press two buttons; one click on one button (the control dial for example) is enough.
    When in the enlarged view mode the exact portion being enlarged can be moved around. One can also pick the area to enlarge before invoking the enlarged mode. This cam be done with the arrow buttons, or, on the current models, using the touch screen if so wanted.
    The view is enlarged in both the viewfinder and on the LCD screen modes.
    regards,
    /Jonas
    Senior Member kds315's Avatar
    Sep 2009
    Weinheim, Germany
    1,440
    On a GH2 you press the wheel under the shutter button on the rear (not left arrow as on GH1). Other than that as Jonas described it.
    Jan 2011
    Devon, UK
    777
    As Klaus says - much easier than on the G1
    Lee
    Gothenburg, Sweden
    1,309
    The control dial = the wheel, no? Am I missing something?
    Jan 2011
    Devon, UK
    777
    Yes I think these are the same thing. On the GH2 the 'wheel', the knurled rotating 'dial' is located on the back of the camera (rather than the front on the G1), just beneath the shutter release. You don't have to touch the 4 way control. The same 'wheel' that, when in normal Aperture priority mode switches between changing AF or EV adjustment.
    It is a lot easier!
    Lee
    Jun 2009
    Vienna, Austria
    145
    thanks for your informative input!
    one more specific question: I tested the focus assist with a gh2 and the 14-42mm kit lens. In manual focus mode, as soon as you start moving the focus ring on the lens, the magnification in the viewfinder changes to 100%, which obviously allows to focus very precisely. Once you stop focussing, it automatically flips back to showing the whole image. This is great, just what I need.
    However, I'd like to use my old manual OM lenses via a OM - micro four thirds adapter. But, since these old lenses have no electronic connection to the body, hwo will I tell the GH2 to switch to 100% magnification now?
    thanks,
    geb
    Senior Member Tesselator's Avatar
    Aug 2010
    Japan
    695
    you have to use the wheel press as is being described. There's no other way AFAIK.
    1,860
    On the GF1 and G3 you can also use the "original" left 4 way button press and then the middle /OK button press (2 button press) but the one press of the rear dial makes a lot more sense to me. With the G3 you also get a PnP as one choice of MF assist but I don't think its available on GH2.
    Jun 2009
    Vienna, Austria
    145
    thanks, very helpful!
    geb
