Results 1 to 2 of 2
Thread: olympus BLM-1 replacement
    Senior Member Peter Klein's Avatar
    Mar 2008
    Seattle
    375
    I'll be needing to get a replacement battery for my E-30. It's the BLM-01 (aka BLM-1), which is used in most of the E-series DSLRs. Does anyone know of a reliable aftermarket battery? Or should I pay the freight for a genuine Olympus-branded battery?
    (I ask because some aftermarket batteries don't properly synch with the charging and battery life circuits, resulting in incorrect reporting of how much charge is actually left in the battery. This is a problem with Leica, I don't know if it is actually a problem with Olympus E-series).
    --Peter
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,929
    Re: olympus BLM-1 replacement
    Quote Originally Posted by Peter Klein View Post
    --Peter
    If you're willing to buy a new battery and charger set, go for the BLM-5 that came out with the E-5. They have additional capacity and seem to last much longer in use than the BLM-1s.
    I've replaced all my old BLM-1s with BLM-5s now ... I bought them from Olympus so they cost a bit, but the additional lifespan is well worth it. The E-1 now gets almost double the number of exposures per charge compared to using the BLM-1.
