Results 1 to 6 of 6
Thread: Is this lens possible/practical/advisable on,,,
    Dec 2011
    Oregon
    4
    Brand new to this forum and M43. I have a G1/14-42 on the way and am wondering about using my Tokina 12-24, F4 (for my D200) on it. Is this a workable thing? I have 24, 28, 35, 50 and 75-150 Zuiko's, but no wide angles. Any input is appreciated.
    Thanks,
    Gerry
    Pratamnak
    9,342
    2157
    Re: Is this lens possible/practical/advisable on,,,
    It will work with an F-mount adapter, but like most modern F-mount lenses, I assume that it doesn't have an aperture ring (correct me if I'm wrong), so you'll only be able to use it at max aperture. You'll get a relatively useful focal length range of 24-48mm eqv., and corner sharpness will probably be better than on your Nikon, but anything about image quality will only be guesswork until you've tried it.
    I would buy a cheap adapter to try it out.
    May 2009
    Southport, Australia
    1,429
    Hi
    Quote Originally Posted by GerryM View Post
    it will be restricted to manual focus only and won't have aperture control in any way. I always found the 12-24 on my EOS 20D to be quite a lump, so it'd be even more of a lump on the m4/3
    my advice would be get either of the 9-18 zooms. Either the dedicated m4/3 one if you're sure you'll never go and get a 4/3 or the 4/3 one with adaptor. I used mine on my G1 (the ZD 9-18) and quite liked it (was a bit slow to AF but the manual 'focus by wire' instantly started the viewfinder magnification so was great.
    for instance all the wides in this set were taken with the 9-18 ZD lens
    vaticanInterior by obakesan, on Flickr
    it did also tempt me to pick up a Oly 410 as another compact camera too ... but that's another story
    Dec 2011
    Oregon
    4
    Thanks for your input. seems like a dedicated M43 lens may be the best way to go.
    Pratamnak
    9,342
    2157
    I have to agree with Pellicle here. Another option is of course the rather expensive but excellent Panasonic 7-14mm. Here's a photo I took with it at 7mm using the GH1 a few weeks ago. I'm holding the camera in my right hand while you can see part of my left arm to the left in the photo.
    Remember also that the Tokina isn't much wider than the m4/3 kit lenses, and the relatively inexpensive Panasonic 14-45mm, which also includes OIS, is an excellent lens too.
    Nov 2008
    Chonburi Thailand
    581
    Having instigated the thread relating to the Panasonic 7-14 I finally took the plunge and this week bought the lens. it's quite simply amazing. Tack sharp, beautiful colours and worth every cent.
