Results 1 to 15 of 15
Thread: Small flash for GH2
    Jan 2010
    317
    Small flash for GH2
    I'd like to get rid of that, to my mind amateurish, pre-flash the pop up flash produces.
    I've just been looking at some twenty year old shots I took with a Canon and using a shoe mounted flash as a fill outdoors. I like them.
    Is there a small flash I can put on the GH2 hotshoe that does not pre-flash and is not one of those tall vertical flashes like this one:-
    http://m43photo.blogspot.com/.../08/...lash-unit.html
    and which simply look silly on a GH2.
    I'd like one that is wider than it is tall - or even square. The FL360 looks like a flash gun with a camera attached to the bottom IMHO.
    All ideas welcome.
    Tony
    Jun 2009
    San Diego, CA
    776
    Re: Small flash for GH2
    How about the Nikon SB-400?
    -Dragos
    Panasonic GH1/G1, Canon FTb(n)/F-1, Mamiya C330F/RB67 Pro SD, Chamonix 45N-2, Nikon F5 + Assorted Lenses
    Jan 2010
    317
    "Nikon SB-400? "
    Looks perfect. Price is fine.
    Presumably it meters OK with the GH2?
    Tony
    Member kwalsh's Avatar
    Sep 2009
    147
    No, it won't meter at all with anything but a Nikon camera and it has no manual output control at all either. Not a good flash for m43.
    Ken
    Jan 2010
    317
    Thanks kwalsh,
    Next suggestion please!
    Tony
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    Quote Originally Posted by Tonygamble View Post
    Is there a small flash I can put on the GH2 hotshoe that does not pre-flash ..
    The answer is no. If you want TTL then the pre-flash has to fire to make a measurement!
    Jan 2010
    317
    "The answer is no. If you want TTL then the pre-flash has to fire to make a measurement! "
    Unlike my recently owned Canon 5d which had ETTL and on which I used the 220 flash gun.
    Or maybe it did pre-flash but much faster than the GH2 does.
    Tony
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    They all (every system) preflash. You notice the pop-up's preflash because the whole out put is small. So, relatively, the weak preflash is more noticeable.
    Jan 2010
    317
    V
    Do you use a hot shoe flash?
    If so, do you notice the pre-flash?
    Tony
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    I had to search for my little flash to check (it is a generic TTL flash, I had already posted information on this for a query you had, a long time ago).
    Yes, there is remarkably a big delay between the pre-flash and the actual flash even with the shutter speed at 1/160s (Camera- GH-2). Thus, it would indicate an enormous shutter lag!
    I am not sure if this is the case with Pansonic flash or the Olympus flashes though.
    Jan 2010
    317
    V.
    Sorry to have asked twice. So far the Nissin Di466 seems to be the best from this, my second, investigation.
    "I am not sure if this is the case with Pansonic flash "
    I'll be going to Focus at the end of the month in Birmingham. I'll try a Panasonic one on their stand.
    Tony
    Senior Member bensonga's Avatar
    Alaska
    2,416
    819
    This Metz might be worth checking out too.....
    Metz mecablitz 24AF-1 Digital Flash for Olympus / MZ 24312OPL
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    V.
    Tony
    No worries, Tony.
    Please report back on how the Panasonic flash works.
    Jan 2010
    317
    Bensonga,
    Thanks for the pointer to the Metz.
    I felt the Nissin offered a bit more control at the gun itself.
    But the test is first to see what a Panasonic does delaywise.
    Both the Metz and the Nissin would never be stocked in a London shop and returning one to an internet seller as the 'delay was too long' would be a bit fraught.
    Tony
    Jul 2009
    190
    After reading about this subject (again) on dpreview, I decided to try the Nissin Di466. It arrives tomorrow. I will report how it works out for me.
    Reed
    My Lumix Blog: DMC-365.blogspot.com
