I heard that is the 5 axis stabilisation gyroscope (located in the hump, near the EVF)) doing the job.My OM-D just arrived with the kit lens. Looks great, feels great in the hand. However, when it is turned on there is constant low level whirring noise. The noise goes away when shooting video. I'm wondering if this is the same for all cameras or if I have a problem.
Mike
Actually in the PENs you are right I could not hear that noise. But from the E3 and E5 I definitely know it was there, but at a much lower level, so maybe many did not even notice it.The noise on this camera is new and different from the older pens. Yes, it is normal and for some people really irritating. Yes, it is normal that it is still there when you turn IS off and yes it diminishes when you are shooting video. Lots of extensive threads on it at DPReview and it is mentioned in their review of the camera.
Indeed it goes away.If the camera is set to auto-sleep in a short time, will the fan noise go away when it's sleeping? Just want to make sure it won't be a battery drain.
I have normal hearing, it is trivial to hear it in a quiet room with the camera held at arms length. Very obvious when using the EVF. It is band-limited white noise, like a small fan or hard drive as some have described. Very inoffensive and not really distracting (to me at least) and unlikely to be heard by anything other than a macro subject and the photographer.I'm inclined to think one needs bionic ear implants in order to actually hear it!
Ah, that might explain it. I tested it with the 12-50 kit zoom only. I did put the Nikkor 105mm f/2.8 G on it for a bit but I didn't try to hear the noise while it was on. I put it on only to check how everything handled while shooting at 1:1 ratios hand-held. It did great BTW!Well, on the kit lens I simply cannot hear it (12-50)
On the 100-300 it's quite obvious (but not a problem)
I'd do some more research but it really is a non problem (for me at least)
I think it's the IS . . . . with mine it doesn't happen with the 12-50 kit . . . but it does with both the panny 100-300 and the zuiko 45 f1.8.Got a new OM-D today and it has the same noise. Very strange. Is there some idea what that could be?
