Results 1 to 5 of 5
Thread: OM-D Image Stabilization
    122
    What to input when manually setting the IS for use with a legacy lens?
    You can set the focal length to match the lens, but has the setting to be made in m4/3 terms or in 35mm terms? (I assume manual settings are redundant with m4/3 lenses since the focal length will be picked up automatically).
    Would it make any real difference? possibly not, but enquiring minds want to know.....
    Aug 2010
    168
    Re: OM-D Image Stabilization
    Quote Originally Posted by les View Post
    You set the actual focal length of the legacy lens, i.e. if using a Zuiko 50mm f1.8, you input 50mm. It DOES make quite a difference to the IBIS performance.
    122
    Quote Originally Posted by Glenn View Post
    Glenn,
    Thanks, that's what I've been doing, but I had small nagging doubt about it, since the manual wasn't specific.
    Agree that the IBIS system works well on the OM-D with old lenses. My old 18-200 Tamron was pretty much unusable on a G3.
    Jul 2009
    Swiss Alps
    1,444
    3
    Glenn,
    Are you changing the focal length indicated for the IBIS each time you are zooming in or out ? That should be a real hassle.. I prefer legacy primes to that .. and keep IBIS off unless needed in order to diminish the hassle.
    122
    Well someone who was particularly precise might I suppose adjust the IS setting to match every turn of the zoom lens. (In fact that's not so much of a pain as it might sound - a few seconds to touch a few buttons, easy after you've done it once or twice - except maybe in freezing weather).
    But in the real world if i connect the 'big' zoom it's usually going to be just used towards the top end, and so I just set the IS once for the zoom's max (in my case 200) and that seems to work fine - for my purposes at least. Obviously if you're using a legacy prime it's easier to be consistently precise and 'go by the book', by setting the IS once to match the chosen lens.
