Results 1 to 15 of 15
Thread: Olympus ZD 50mm F2 vs Panny Leica 45mm F2.8 on OM-D
    Mar 2011
    187
    Will be buying one of these solutions to use on the OM-D.
    PL45 advantages:
    Much Faster AF
    2:1 Magnification (on 35mm equivalency)
    Compact and Small
    Possibly better LOCA performance
    Oly 50mm F2 advantages:
    Weather sealed with MMF-3
    1 full aperture faster
    Possibly better bokeh
    100mm is better than 90mm
    Possibly slightly sharper
    Different review sites tend to go back and forth on which one is sharper. My guess is that they're probably pretty close and the Oly ZD might be slightly sharper. I tend to trust the DPReview site more because they have more expertise than say TechRadar or ePhotozine.
    Right now, I'm leaning heavily on the Olympus solution because of the weather sealing primarily, full aperture stop advantage (useful for portraits), and slightly sharper reputation. The PL45mm though really gets me on the very clean LOCA and AF speed which will probably be very useful. I wonder if perhaps the Oly 50 ZD LOCA might go away as you go to F2.8 or F4.
    I plan to shoot this combo in the rain and snow so the weather sealing would be a big win. Then again I can just cover the PL45 in a plastic bag and it'll be sort of weather sealed as well and offer more useable AF speeds.
    Oct 2009
    178
    Re: Olympus ZD 50mm F2 vs Panny Leica 45mm F2.8 on OM-D
    Quote Originally Posted by FlypenFly View Post
    the question is - did they test resolution at macro distances (to the target) or not...
    Senior Member kevinparis's Avatar
    Jun 2008
    919
    5
    never realised the the 50mm macro was weather sealed..
    Oly's spec says "dust and drip proof"
    ZUIKO DIGITAL ED 50mm F2.0 Macro | Digital SLR | Olympus Imaging Asia
    Not tried it on the omd..but on gh-2 and ep1 autofocus was not stellar. Then again most macros aren't
    K
    Jun 2008
    919
    5
    You also do realise that only have announced but not yet shipped a 60mm macro for micro 4/3?
    K
    Mar 2011
    187
    Yeah, but I doubt it'll be as optically excellent as the Oly 50 ZD and I actually do want the full aperture stop.
    Secondly, 100mm is one of my favorite FL but anything longer and it becomes too awkward for me. I've tried back in the day with the Sony 135mm STF on full frame and a bunch of other lenses but I just can't use a FL longer than 100mm.
    Gothenburg, Sweden
    1,309
    In my opinion the Zuiko 4/3 50/2 Macro suffers badly from LoCA and it didn't (I've since long sold the lens) clean up really until stopped down to f/5.6. Sometimes OK at f/4. It depends on what you are shooting of course, how much you can tolerate and what you think about PP-ing and the result from cleaned out LoCA...
    The second problem was the focusing speed and the lack of a focus limiter. No third problem really. It's a nice little lens, very clinical rendering so if you like that it will work good for you. The bokeh is neutral, also wide open, and gets slightly worse sometimes stopped down. That probably doesn't bother you much. I noticed it in a few situations only as I didn't use the lens as a macro (mostly wide open in other words).
    My experience with the lens comes from use with a 4/3 camera. I have no idea what the focusing will be like when used with a micro 4/3 camera.
    I have sometimes lusted for the Panasonic 45/2.8. Beautiful rendering.
    Good luck with your decision,
    /Jonas
    Subscriber Member kit laughlin's Avatar
    Two suitcases and the latest MBA
    1,334
    I have owned two copies of the 45/2.8 (and own one now). Both were extremely sharp; not sure how the 50/2 could be much sharper.
    Re. portraits: with both lenses you can get as close as you like. With the 45/2.8 on the OM-D, I am not sure the one stop advantage translates into any real advantage re. DOF control.
    The 45 handles well on the OM-D. It, together with the Oly 45/1.8, are must-haves with the OM-D or any other 4/3rds camera. I haven not used the 50/2, though.
    Aug 2009
    Warsaw, Poland
    188
    I have both. Comparisons of sharpness must be made on the same body to be meaningful. In my opinion both lenses are comparable at all apertures (judging from picture comparisons, not testing). I like the 45/2.8 rendering better, more "filmic". In practical uses the f2.8 I find sufficient. For real shallow DOF on m43 one needs the 75/1.8.
    The focus of 50/2 on m43 is much slower.
    May 2009
    Southport, Australia
    1,429
    I'll wager you won't see much difference between f2.8 and f2 in DoF
    Are you sure the AF is better on the Pana?? If so then I'd go the Pana as you also get macro ability too.
    Unless you like the look of that chrome looking lens.
    Personally I'm still quite happy with my OM 50 1.4 or my Pentax 110 50mm
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,778
    Well, just to muddy the water a bit, I've had both of these lenses, and I'd quite agree with your assesment.
    nowadays on the OMD I use a Leica Elmarit R 60mm f2.8 - it's small and perfectly formed, and IMHO it knocks those other two excellent lenses into a cocked hat. AF is over-rated for macro (especially with the 50 f2 on 43!) Manual focusing is really easy (no need to zoom in and out, it's obvious in the EVF). It would probably also be cheaper!!!!!
    all the best
    Just this guy you know
    Aug 2009
    Warsaw, Poland
    188
    Quote Originally Posted by pellicle View Post
    50/2 is for 4/3 mount and phase detection focus. Even on E5 it is slower than newer SSW motor lenses (12-60 for example). On m43 it is focused with contrast detection and really slower than any dedicated m43 lens.
    Mar 2011
    187
    Quote Originally Posted by nugat View Post
    What's confusing is the pl45 should have done much better because it has a weaker AA filter and it has 2 extra megapixels.
    Gothenburg, Sweden
    1,309
    ...and to that you can add the weather sealing and the extra stop you said you need. It's a pity the Zuiko doesn't come with the Panasonic rendering, fast focusing and freedom (very nearly so) from LoCA.
    For me it would be the Panasonic. Sometimes one has to make a decision and not look back.
    Mar 2011
    187
    Both legendary lenses but for now, I went the ZD 50mm F2 route.
    Aug 2009
    Warsaw, Poland
    188
    What is really confusing is the figures given by the dpreview test.
    L10 sensor is 3648x2736 pixels. The Nyquist limit for this sensor is 2736/2=1368 lp/ph.
    How on earth did they register over 1500??
    It's an old story where for years up to 2010 they not only misused Imatest but confused picture lines/widths with picture line pairs and placed the Nyquist limit according to either measure at random.
    Then when the issue was raised they removed the Nyquist limit line from all old tests (like this one) and discontinued Imatest testing altogether.
    Now they are back to old good resolution charts and "what you see is there" approach.
