Results 1 to 7 of 7
Thread: extreme purple fringing with the 20/1.7 (on em-5)
    Jun 2012
    17
    2
    Hi, I recently found that on a photo taken with the 20/1.7 at 1.7 with the om-d at 400asa (1/640s so I know the best combination for the shot but that's not the point here)
    this is out of camera raw (LR4).
    this is a corrected version done with LR4 (notice the discoloration of the blue webbing thing at the lower left, as well as the "color clouds" in the shadows).
    is that normal seems a bit extreme to me. this was not a test I just discovered it in LR and tried to correct it very easy in LR but the result is of course not very good given the extreme case. I will do some tests with other lenses and other apertures when I find the time. In the meantime I was wondering if somebody else has the same problem with that lens (which I liked a lot on the gf1 and still like on the om-d for some shots but to a significantly lesser degree especially now) or if I might have a defective sample.
    looking forward to your comments.
    simon
    Feb 2008
    Uppsala, Sweden
    187
    Re: extreme purple fringing with the 20/1.7 (on em-5)
    I think your Pana camera automatically fixes a lot of the CA, which the OMD doesn't.
    Leica Monochrom, Olympus EM-5, Ricoh GR
    Feb 2008
    Uppsala, Sweden
    187
    I should add that I have both the 20/1.7 and 14/2.5. Both show CA on the OM-D, especially the 14mm, and of course more at wider apertures. The 14mm actually has so much CA (at any aperture) that I got the Oly 12/2 instead. Otherwise it is a decent performer.
    So I don't think you have a defective lens. You could try opening the Panasonic RAW-files in some software that disregards the camera-applied changes. I think RPP does this: http://www.raw-photo-processor.com/ (Mac only). Then you will see if the lens performs similarly on both cameras.
    Jun 2012
    17
    2
    Quote Originally Posted by pgmj View Post
    yes I know that, ca are not an issue since very easiliy corrected with LR4 and they are not that severe. what is bothering me is the purple fringing wich is removed in LR4 also quite easily but the removal leaves some ugly traces.
    Jun 2012
    17
    2
    hi thanks for the reply.
    I'm sure the om-d didn't make my lens any worse and I know that the pana corrects everything. I don't doubt that with the "right" raw procession software the gf1 would produce similarly bad pictures, but I'm more interested in good pictures with the om-d
    simon
    Jul 2008
    111
    I am not having any problems getting great images using the panny 14mm on the OMD with lightroom 4.2. The two types of CA tools do a great job, in my experience. I am not finding "ugly traces" to be a problem.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    I think the problem is with the camera.
    On the new Sony NEX-6 (APS-C sensor!), the 20/1.7 performs superbly! There are no electronic controls whatsoever.
