Results 1 to 2 of 2
Thread: Olympus 12mm F2 - Is this a good sample?
    Mar 2011
    187
    Just curious if this is the performance I should expect from this lens. If other owners can chime in to indicate if this look about as sharp as a good copy or not, I would appreciate it.
    Opening them in separate tabs might be helpful.
    Full size JPEGs taken in Fine Mode, straight out of camera from natural mode:
    Set 1
    F2
    http://www.jaegraphy.com/lightroom/eraseme/_A260644.JPG
    F2.8
    http://www.jaegraphy.com/lightroom/eraseme/_A260643.JPG
    F4
    http://www.jaegraphy.com/lightroom/eraseme/_A260642.JPG
    Set 2
    F2
    http://www.jaegraphy.com/lightroom/eraseme/_A260645.JPG
    F2.8
    http://www.jaegraphy.com/lightroom/eraseme/_A260646.JPG
    F4
    http://www.jaegraphy.com/lightroom/eraseme/_A260647.JPG
    Set 3
    F2
    http://www.jaegraphy.com/lightroom/eraseme/_A260648.JPG
    F2.8
    http://www.jaegraphy.com/lightroom/eraseme/_A260649.JPG
    F4
    http://www.jaegraphy.com/lightroom/eraseme/_A260650.JPG
    Set 4
    F2
    http://www.jaegraphy.com/lightroom/eraseme/_A260651.JPG
    F3.5
    http://www.jaegraphy.com/lightroom/eraseme/_A260652.JPG
    Set 8
    F2
    http://www.jaegraphy.com/lightroom/eraseme/_A260662.JPG
    F2.8
    http://www.jaegraphy.com/lightroom/eraseme/_A260663.JPG
    F4
    http://www.jaegraphy.com/lightroom/eraseme/_A260664.JPG
    Set 5
    F2
    http://www.jaegraphy.com/lightroom/eraseme/_A260653.JPG
    F4
    http://www.jaegraphy.com/lightroom/eraseme/_A260654.JPG
    Set 6
    F2
    http://www.jaegraphy.com/lightroom/eraseme/_A260656.JPG
    F2.8
    http://www.jaegraphy.com/lightroom/eraseme/_A260657.JPG
    F4
    http://www.jaegraphy.com/lightroom/eraseme/_A260658.JPG
    Set 7
    F2
    http://www.jaegraphy.com/lightroom/eraseme/_A260659.JPG
    F2.8
    http://www.jaegraphy.com/lightroom/eraseme/_A260660.JPG
    F4
    http://www.jaegraphy.com/lightroom/eraseme/_A260661.JPG
    Member jnewell's Avatar
    Feb 2012
    Boston, MA USA
    92
    Re: Olympus 12mm F2 - Is this a good sample?
    I'm in a bandwidth-constrained location, but I will tell you that I tried two of the 12/2s in an informal but careful comparison against my 12-35/2.8 and 7-14/4 and, at the same apertures, the 12/2 was noticeably less sharp in the center (as well as the edges - but that was less of an issue). There's at least one reviewer who said that he went through two before he got a third that he was pleased with. There seems to be a bit of variability with the 12/2.
