Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 201 to 250 of 283
Thread: M4/3 to Leica
  1. #201
    Brooklyn
    4,043
    1253
    Re: M4/3 to Leica
    i am shipping the LTm to G1 adapters tomorrow.
    e-mail me for details
    [email protected]
  2. #202
    Nov 2008
    3,848
    Re: M4/3 to Leica
    Quote Originally Posted by willpix View Post
    One more thing I'd like to confirm with one of you knowledgeable G-1 shooters. I believe I read elsewhere that any lens with a rear element protruding beyond the G-1>Leica M adapter is unusable. That means no marriage between the Panny G-1 and my cherished 21mm f/3.4 Super Angulon, right?
    Nope!
  3. #203
    Wisconsin
    3,581
    118
    Re: M4/3 to Leica
    Sad, but true. It would have been so sweet if we could have used the SA on the G1.
  4. #204
    Senior Member back alley's Avatar
    Feb 2008
    the frozen north
    428
    3
    Re: M4/3 to Leica
    i hope my zeiss 21/4.5 fits in there ok...
    this is pretty exciting really, using my zm lenses on this little digital.
    joe
  5. #205
    Nov 2008
    3,848
    Re: M4/3 to Leica
    How far does the rear element extend on the 21?
  6. #206
    Feb 2008
    the frozen north
    428
    3
    Re: M4/3 to Leica
    i'd have to measure but just looking at it? not very far, no where near the 21 leica.
  7. #207
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Re: M4/3 to Leica
    Quote Originally Posted by back alley View Post
    joe
    That C-Biogon would be a no go.
  8. #208
    Feb 2008
    the frozen north
    428
    3
    Re: M4/3 to Leica
    that's disappointing.
    have you tried it?
    joe
  9. #209
    Senior Member Per Ofverbeck's Avatar
    Feb 2008
    503
    5
    Re: M4/3 to Leica
    The dangerous thing with the G1 when mounting lenses is the shutter. Since its normally open, it is easy to overlook. It closes and reopens very quickly at the start and end of each exposure, and is difficult to actually see (there is a slow-motion film of it somewhere; Ive lost the link).
    Ive done a couple of measurements on mine with a caliper (very carefully), and enclose a rather blurry picture of the lens mount and innards of the camera. The large, flat surface at point A in the pic is situated 6.5 mm below the plane of the lens mount front; Id say thats about the safe limit for anything to intrude into the camera.
    The frame seen at B is the shutter window; the blades pass *immediately* below it. That frame is 10.5 mm below the lens mount front surface, and anything intruding more than that means certain disaster at first exposure! I would subtract at least 2 or 3 mm as a safety margin.
    The sensor surface itself is several mm below the plane of the shutter window, but Ill be d*mn*d if I will put a caliper point to it...
    Finally the customary disclaimer: Ive done the measurements to the best of my abilities, but I take no responsibility whatsoever for what might happen if you mount anything on your camera: you have to measure yourself!
    I post these results only to help those who havent yet access to the camera, but want to get some idea of what lenses may be safely mounted.
    I hope that Vivek or Jlm,, or somebody else can fill in with the effective height of the converters; Im still waiting for mine.
  10. #210
    Nov 2008
    3,848
    Re: M4/3 to Leica
    Here is the link to the shutter video:
    http://www.youtube.com/watch?v=-dK6Qa1Iy4Y
  11. #211
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Re: M4/3 to Leica
    have you tried it?
    joe
    No. I haven't lost 'it', yet.
    If previous posts here have no meaning, you try it and describe to us how the shutter looks before and after.
  12. #212
    Brooklyn
    4,043
    1253
    Re: M4/3 to Leica
    the distance between the LTM flange and the G1 flange is very close to .400", (10 mm). if your lens element is less than 1.10" (28mm) diameter, it can extend another .200 (5mm). so a lens with a rear element of less than 1.17" can extend .600" beyond its base flange, assuming the lens is measured at inf focus, and assuming that is where the lens extends the most
    if the element is larger diameter, it will interfere the spring-loaded electrical contacts in the body, in the case of a larger, no more than another .12", or .52" total.
    for example, the CV 15 extends about .56" and is 1.06" in diameter, works fine
    the 12mm CV also extends about .56" and is .87" dia (at the interference end) and works fine
    The M to G1 adapters hold the lens flange about .040" closer to the G1 flange, so the numbers get reduced by .040"
    for example the WATE extends .420" (.99" dia), that is less than .52 and will work fine
    the 28 Cron extends .47" (1.14 dia) and that will work
  13. #213
    marknorton
    Re: M4/3 to Leica
    I'm not sure I understand John's exaplanation exactly, but I rushed home to measure the three other lenses I might like to use on the G1: 21mm Elmarit ASPH, 24mm Elmarit ASPH and 35mm Summilux ASPH - they all have a rear lens diameter of 29mm (1.142") and a maximum extension behind the flange of 13mm (0.51").
    John, will these lenses be OK?
    Others, like the Noctilux, 75mm's and 90's are fine. The 50mm f2.8 Elmar is obviously a no-no if you try to collapse it. The 90/4 collapsible Elmar will make a lovely 180mm f4 lens and because it does not project beyond the bayonet will be fine. Judging by the pictures on the Leica web-site, the 21/1.4, 24/1.4, 50/0.95 will be fine as well as their rear lenses do not appear to extend beyond the bayonet. Assuming of course the pictures are of real lenses, not mock-ups.
  14. #214
    Brooklyn
    4,043
    1253
    Re: M4/3 to Leica
    they should fit
  15. #215
    Nov 2008
    3,848
    Re: M4/3 to Leica
    I'm confused: is the 1.10" in the above paragraph supposed to be 1.17"?
  16. #216
    Brooklyn
    4,043
    1253
    Re: M4/3 to Leica
    oops! the number should be 1.7"
    jm
  17. #217
    Nov 2008
    3,848
    Re: M4/3 to Leica
    1.7" = 43mm? You sure?
  18. #218
    Brooklyn
    4,043
    1253
    Re: M4/3 to Leica
    oh man...1.170"
  19. #219
    Nov 2008
    3,848
    Re: M4/3 to Leica
    John, does this look correct?
  20. #220
    Feb 2008
    the frozen north
    428
    3
    Re: M4/3 to Leica
    my most precise measurement tool is a craftsman tape measure...so for what it's worth...
    it looks like, on the zm 21/4.5, that the distance from the flange to the rear of the lens is 13 mm - and 12 mm for the 25/2.8
  21. #221
    Nov 2008
    3,848
    Re: M4/3 to Leica
    Those measurements look ok as long as your Craftsman and your measuring technique are sound.
    And as long as the diameter of the rear part of the lens is <29.7mm.
  22. #222
    Feb 2008
    the frozen north
    428
    3
    Re: M4/3 to Leica
    looks to be a hair over 26 mm.
  23. #223
    Nov 2008
    3,848
    Re: M4/3 to Leica
    Lookin' good so far, Joe.
  24. #224
    Central Texas
    182
    Re: M4/3 to Leica
    Is it safe to assume the 50 lux asph and pre-asph as well as the 90 asph will work? Thanks
  25. #225
    marknorton
    Re: M4/3 to Leica
    I thought I'd better get out my electronic calipers to measure that rear lens diameter more accurately:
    21mm Elmarit ASPH: 29.10mm
    24mm Elmarit ASPH: 29.04mm
    35mm Summilux ASPH: 29.00 mm
  26. #226
    Nov 2008
    3,848
    Re: M4/3 to Leica
    Quote Originally Posted by wolverine View Post
    I wouldn't think those would have any issue...its the wides with extended rear elements that are the problems.
  27. #227
    Nov 2008
    3,848
    Re: M4/3 to Leica
    Quote Originally Posted by marknorton View Post
    Looks like 1mm or less to spare, in diameter and in flange-to-rear lens distance, but that's enough.
  28. #228
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Re: M4/3 to Leica
    All these discussion about which one hit the shutter is a bit redundant if you look the pics of the adapter posted by Bill.
    If a lens fits that adapter, it will fit the camera.
  29. #229
    Nov 2008
    3,848
    Re: M4/3 to Leica
    Vivek, you've got it backwards. The adapter photos are redundant.
  30. #230
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Re: M4/3 to Leica
    Yes, both are redundant for me.
  31. #231
    Central Texas
    182
    Re: M4/3 to Leica
    Any plans for a leica R to mFT adapter?
  32. #232
    Nov 2008
    3,848
    Re: M4/3 to Leica
    Novoflex will have one in February, or, you can use Leica R glass now using two adapters (Leica R --> 4/3 and 4/3 --> 4/3)
  33. #233
    Central Texas
    182
    Re: M4/3 to Leica
    Are two adapters like doing an extension tube? I have always thought that the further the lens gets away the closer you focus?
  34. #234
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Re: M4/3 to Leica
    Yes, it is. Just like using an extension tube.
    However, here, if the lens' infinity focus is preserved in spite (or because) of the adapter, then it would behave like a normal lens. There is no light lost and the focal length of a lens does not change due to smaller or bigger sensors.
    The G1 and a Leica M adapter is now a camera that can take Leica M lenses.
    The G1 + a Leica M adapter plus a Leica M to LTM adapter makes it a camera that accepts and works with Leica thread mount lenses and so on.
    So, this modular approach is even more versatile than Tamron's line of Adaptall design lenses.
  35. #235
    marknorton
    Re: M4/3 to Leica
    All very interesting. I'm looking forward to a live view through a Noctilux, though presumably, if the adapter restricts the diameter to 29mm, will that cause problems with larger rear elements than that? The Nocti is about 34mm but doesn't project backwards like the wide-angles.
  36. #236
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Re: M4/3 to Leica
    Some of the shots I posted here were with a Canon 50/0.95.
    The rear diameter calculation/confusions left me scratching my head (only briefly).
    That lens' (50/0.95) rear element does not protrude outside the lens mount but has a diameter of ~36mm.
  37. #237
    Nov 2008
    3,848
    Re: M4/3 to Leica
    Assuming the chart accurately reflects John's post, the Noct would be fine if it extends less than 9mm.
    I sold one a few weeks ago, would have been nice to see it on a G1. Although it will be very Dolly Parton-ish, front heavy.
  38. #238
    marknorton
    Re: M4/3 to Leica
    There's no issue about the Noctilux lens projecting too far back. I just wondered what the effect of the 29mm (or so) hole will be when the lens diameter is 34mm (or so).
  39. #239
    Nov 2008
    3,848
    Re: M4/3 to Leica
    How much of that 34mm consists of retaining ring? I wouldn't think it would cause any problem.
  40. #240
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Re: M4/3 to Leica
    It won't cause any problems. As I already said, if a lens fits the adapter, it is ready to be used.
    Monza, Dolly Parton?! Are you ancient as well?
  41. #241
    Nov 2008
    3,848
    Re: M4/3 to Leica
    No, I have a black G1, that makes me a young whippersnapper. Otherwise I'd have a red one.
    OK Pam Anderson?
  42. #242
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Re: M4/3 to Leica
    No,no, no. That isn't it.
    No comparisons to any body parts (whatever gender).
  43. #243
    akaloith
    Re: M4/3 to Leica
    Can you please post FULL SIZE raw and jpeg samples of your great Leica Lenses on Panasonic G1?
    By posting a 1mp sample means nothing about image quality
    Very easily a crap lens could be good at 1mp!
    PLEASE FULL SIZE!
  44. #244
    Senior Member kevinparis's Avatar
    Jun 2008
    919
    5
    Re: M4/3 to Leica
    actually I would like someone to take a 'classic leica look' picture ( eg not a brick wall, haphazard collection of booze bottles, coloured pencils and fluffy toys)... maybe a street scene or an indoor natural light portrait on
    1) M8
    2) G1
    and if possible
    3) RD 1
    Dont care which lens you use.. lux cron or 'it... just the same shot
    you can even use PP... but the same to all shots
    just curious
  45. #245
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Re: M4/3 to Leica
    Quote Originally Posted by akaloith View Post
    PLEASE FULL SIZE!
    Sorry. I NEVER post any full size (any format) pictures.
  46. #246
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Re: M4/3 to Leica
    Quote Originally Posted by kevinparis View Post
    1) M8
    2) G1
    and if possible
    3) RD 1
    just curious
    Be nice to Jono!
    He is the only one who has all the three cameras you mention!
  47. #247
    marknorton
    Re: M4/3 to Leica
    I think Jono has most cameras actually...
  48. #248
    Jun 2008
    919
    5
    Re: M4/3 to Leica
    I am always nice to jono :-) as far as I recall I have never personally insulted him....
    I may have expressed an alternative perspective on a camera he loves... but that was all in the spirit of lively debate and discourse... which of course ended up with mild disagreement about who was most correct :-)
    truth be told... I really envy my other half's lenses... even the ones she casts aside... and would love to see my comparison request.
    k
  49. #249
    belge
    1,492
    2
    Re: M4/3 to Leica
    nope, Jono has forsaken my beloved R-D1, sniff, sniff...
  50. #250
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Re: M4/3 to Leica
    Kevin, I did not imply you personally attacked Jono at all. I did not read that earlier exchange like that.
    Having used the M8 sporadically and having owned and used the R-D1s for a while, I can only say this. The M8 wins easily in terms of image clarity (despite the IR/UV problems it has). It is a toss up between R-D1s and the G1.
    Price, versatility and many other factors easily favor the G1 over the two.
    BTW, akaloith, read Jack's reply here: http://forum.getdpi.com/forum/showthread.php?t=4304
