Page 2 of 2 FirstFirst 1 2
Results 51 to 54 of 54
Thread: Canon 50/1.2 for LTM: worth having?
  1. #51
    Ithaca, NY
    3,538
    Re: Canon 50/1.2 for LTM: worth having?
    Carl, I like the way that lens renders...how does the camera/lens combination feel? Is it a little front-heavy? Could you do a side shot of the G1 with lens and adapter?
    Interestingly, I just received my Canon Lens Converter B today. Add an LTM adapter, and presto, it becomes a Canon FD --> Leica M adapter. But I don't have any FL or FD lenses yet to play with.
    Robert, The 50mm 1.2 balances quite nicely on the G1 - not a huge lens like the 25mm Summilux. Here is a top view shot with the lens mounted via the Rayqual FD-MFT adapter. The latter is anodized aluminum and very light weight.
    Regards,
    Carl
  2. #52
    Ithaca, NY
    3,538
    Could be interesting for portraits, Carl. It appears that CA could be a problem.
    Are you using a long enough hood on it?
    Vivek, I don't have a hood for this lens yet, but I will need one for sure. There is some CA, but not too bad and I didn't correct for it in the raw conversions (LR 2.2).
    Regards,
    Carl
  3. #53
    robertasumendi
    Since the Canon Lens Converter B was mentioned here in this thread, I thought I'd mention that this adapter doesn't allow you to change the aperture... you're shooting wide-open all the time. No idea why Canon would design such a thing for their own lenses but there you go. Might be a good footnote to add to the adapter chart under LTM+FD.
  4. #54
    Nov 2008
    3,848
    The Converter B with work with FL or FD lenses, but with FD, the aperture lever on the back of the lens must be secured in the stopped down position.
    Not required with FL lenses...
