Results 1 to 5 of 5
Thread: Stop down on G1 for MF with adaptor?
    tkelly
    I am intrigued by the idea of using the G1 with small fast primes in available light. In Sean Reid's review of the Milich GT adapter, he says it makes sense to focus with a lens wide open and then stop down to take a picture. Would this be the case with fast lenses and fast to moderate apertures (say <f2.8), or just when using small apertures (say >f8)? If you were using a CV 35/1.2 at f2.5 (or less), which is the same aperture as (or wider than) a CV 35/2.5 wide open, why would you need to focus the f1.2 lens wide open?
    On a somewhat related note, Sean's review of the CV28/2 notes some focus shift problems. Would focus shift be an issue when used on the G1, or would you just focus at the taking aperture?
    Senior Member Amin's Avatar
    Boston, MA (USA)
    1,809
    Re: Stop down on G1 for MF with adaptor?
    Quote Originally Posted by tkelly View Post
    You would have a less noisy EVF and more precise focus if you focus wide open and then stop down to shoot. However, focusing with the lens already stopped down is no different than focusing with a slower lens wide open.
    If you focus wide open and stop down, focus shift will be an issue. If you focus at the taking aperture, focus shift will not be an issue.
    302
    Amin
    What about shooting outside with an f stop of say f 8 - 11??
    Is the evf bright enough to focus stopped down??
    BTW I am thinking of purchasing a Zeiss 18mm to use with the G1.
    Also, I might use my mothballed Voightlander 15 mm with the G1?
    What do u think??
    Martin
    Terry's Avatar
    New York City
    6,955
    1145
    I'm going to use my CV12 on the G1. I haven't tried the stopped down of a MF lens outside yet!
    Nov 2008
    3,848
    Yep, it works well in bright sunlight even at f8 or so.
