Results 1 to 8 of 8
Thread: What Ratio Do You Use?
    Senior Member barjohn's Avatar
    Galveston, TX
    947
    171
    If I read the manual correctly, you only get 12mp when using 4:3 ratio. I have mine set to shoot in 3:2 ration which only gives only 10.7mp. Any thoughts about this? Anyone normally shoot in 4:3? Are there any advantages? I have taken shots trying all three and can't really discern much difference.
    V/r John
    Terry's Avatar
    New York City
    6,955
    1145
    Re: What Ratio Do You Use?
    The other ratios are generally crops so you get the most information with 4:3. There are some cameras made by Panasonic that have a larger sensor that allows for better use of the image circle but then it wouldn't be a 4:3 sensor.
    I think if I am shooting side by side with the M8 and want to make sure I'm consistent I might change to 3:2.
    Senior Member Per Ofverbeck's Avatar
    Feb 2008
    503
    5
    FWIW, Iīve had the G1 for almost 2 months now, and still havenīt shot a single frame other than 4:3; itīs just perfect for me (and the same as the Digilux 2). 3:2 is just too narrow for me; I always cropped my 35mm film shots. The 16:9 on my Dlux 3 was fun for a while; now I seldom use it.
    But thatīs me. If another aspect ratio worked better, Iīd set the camera for it and not give a d-n about the MP "loss" (Iīd get it anyhow, by cropping after the fact...).
    413
    I always shoot 4:3 with the G1. The full 3000 X 4000 pixels give room to level and/or crop (to 2:3) the picture if needed.
    Los Altos, CA
    10,486
    1031
    Ironically, one of the main reasons I looked to the 4/3 cameras was after shooting with my medium format camera also at 4:3, I so enjoyed that aspect ratio I wanted my smaller carry camera to have it too! And like Peter says above, you can always crop the 4:3 to any of the other choices after the fact -- even better this way IMO as you get to see what you're losing as you do it
    home: www.getdpi.com
    Senior Member peterb's Avatar
    Tysons Corner, Virginia
    490
    18
    I started out shooting 3:2 but then switched to 4:3 since (A) I shoot RAW and (B) I realized that I might as well get it all since I'm gonna crop and post process to my specs later anyway.
    Interestingly, my post processing with the G1 has been very simple. I find for the most part it's only necessary to tweak the blacks or brightness. (Rarely, I may have to adjust the lighting temperature. But that's EXCEEDINGLY rare.)
    In normal exposures I usually raise black level to about +16 from the default or to +22 or +32 on more backlit situations.
    Brightness is kept at the default unless the shot's a little too under exposed where I want to bring out black backgrounds. Then I push the brightness from it's default to around +90 - +100 depending on the subject.
    If I'm not satisfied with the sharpness (which is usually quite good with the kit lens and I am looking forward to the day when I can get an M adapter and use some of those lenses on the thing) I apply an unsharp mask at 45% (for women) and 80% for everyone else. (Not to be sexist or anything but when I'd applied the full 80% some ladies were a little upset with the detail that was revealed so I dialed it down and folks have been most pleased with the results.) At the most I will go to the default "auto sharpen".
    On occasion I may adjust the lighting histogram if it calls for it (like in a winter scene). But, for the most part, I found with this camera that exposure has been spot on.
    With BW images I convert at the RAW level (dialing down saturation) and adjust black and brightness accordingly.
    If some minor blemish correction or horizon adjustment is required, after all has been done, then I use the necessary tools. But for the most part I prefer to work in 16 bit and keep that way as long as possible.
    Then when all is said and done I create the various crops for individual files.
    I shoot in ISO 100 to 400 as the noise according to what I've read is VERY low vs other cameras out there.
    I'd be curious to know what others do as I'm always open for helpful suggestions.
    P
    By the way, the G1 has been simply awesome for portraits. With the articulating screen you can use it almost like a twin lens reflex keeping an eye on your subject and engaging him or her while shooting and insuring you're properly focused and framed.
    Life is an infinite series of moments called..."now".
    My job is to capture them.
    Senior Member back alley's Avatar
    Feb 2008
    the frozen north
    428
    3
    nice shot
    Galveston, TX
    947
    171
    Great! Thanks for all the responses. I think I will switch to 4:3 going forward.
    V/r John
