Results 1 to 3 of 3
Thread: Bellows set up for Lumix G3 camera
    Feb 2009
    793
    I have a lumix G3 and would like to use older canon FD bellows. Can anyone tell me the components i need including a very sharp lens for the bellows.
    thanks
    Senior Member JBurnett's Avatar
    Aug 2009
    Bridgewater, Nova Scotia
    530
    2
    Re: Bellows set up for Lumix G3 camera
    You'll need a Canon FD to Micro-4/3 adapter at the camera end. As this is a Canon FD bellows, you should probably start by looking at Canon FD-mount macro lenses, rather than adapting something else. The FD 50mm f/3.5 macro lens, for example, can be used on it's own (.5x or 1X with extension tube), or on the bellows. The Canon FD 35mm f/2.8 Macrophoto lens is a dedicated bellows lens and has no focusing mechanism of its own. When used on the bellows, it will provide magnifications from about 2X to 6X life size, I think. The 20mm f/3.5 macrophoto will provide magnifications of between 4X and 10X life size. What will work best for you will depend on the magnification and working distance that you need.
    Best regards,
    John.
    http://jburnett.ca
    Feb 2009
    793
    Thank you
