Results 1 to 4 of 4
Thread: OM-D EM-5 help needed...
    Member kai.e.g.'s Avatar
    Jan 2008
    Friuli-Venezia-Giulia, Italy
    150
    I have an unusable rear LCD screen on my OM-D (it cracked when I took a tumble with it). The camera continues to work fine with just the EVF, of course, but I need to keep using it for at least another couple of weeks for some important up-coming events before I send it away for repair. There are two things that don't work for me:
    1) I can't access the main menu, since as far as I know, it only displays on the rear LCD. There may be nothing I can do about that (fortunately, I have the super menu activated, and I can see that in the EVF). I wouldn't need it at all, except....
    2) I can't play back images for the same reason. I believe this can be fixed, but I need somebody's help to do it.
    In truth, I can live without both these things for the short term, but it would be nice to "chimp" sometimes for one of the trips we'll be doing, as I'll be shooting in pretty low light. I have read that it's possible to switch playback to the EVF, by pressing the button on the side of the EVF for several seconds, then switching whatever setting comes up on the rear screen to "no", except I can't see that, and despite blind guessing which buttons I should press at that point, I can't make it happen. Could I trouble some kind soul to please tell me what sequence of buttons to press to get image playback in the EVF, bearing in mind that I can't see any menus on my LCD?
    Member slosync's Avatar
    Jan 2009
    Florida, USA.
    97
    Re: OM-D EM-5 help needed...
    Quote Originally Posted by kai.e.g. View Post
    I fiddled with my EM5 but didn't come up with any messages as you mentioned above. What I did: I pressed the image playback. Pressed the button on EFV and reviewed images via the EVF. My setting for the EFV is not to automatically switch when putting my eye on EFV. That's the only way I could "chimp" using the EFV.....
    Good luck... hope that helps.
    Don
    Jan 2008
    150
    Thanks, Don. I think that could be my problem: my camera was set to automatically switch, and in that mode it never shows played-back images in the EVF, even if your eye is up to it. A short press of the button next to the EVF does nothing for me in any mode right now. A long press of that button might be displaying the menu option I read about elsewhere... but I can't be sure!
    I have to say that it's been fun using the camera a bit like an old film camera lately - not knowing how shots turned out until getting home in the evening!
    Jan 2008
    150
    I solved it! That setting for turning the auto-switch EVF on/off when you long-press the EVF button only comes up when you're in shooting mode, and I was only doing it when in playback mode. Switching off auto-eye detect was all that was needed to get playback working in the EVF. All is good now, I can chimp my photos of the weird mountain festival we'll be going to next week ;-)
