Results 1 to 26 of 26
Thread: Firmware Update v1.4 for E-M1
    Knorp's Avatar
    3,993
    Arrow Firmware Update v1.4 for E-M1
    You know the procedure: hook up your E-M1 to your computer and start the updater ...
    Not much to be found yet on the support sites though, but I've just loaded v1.4.
    Anyways, here's the link to what's changed: Ver.1.4 (May.21 2014)
    Kind regards.
    Bart ...
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,928
    Re: Firmware Update v1.4 for E-M1
    Quote Originally Posted by Knorp View Post
    Kind regards.
    Thanks! Updated... :-)
    Hampshire, UK
    904
    20
    Another thanks! All updated successfully.
    Cheers, Dave
    www.simmondsphotography.com
    Godfrey's Avatar
    Jan 2009
    7,928
    I've had precious little time to experiment, but fitting the 35 Macro and 11-22mm, AF does seem a bit snappier and more positive than with v1.3 fw.
    Member Matix's Avatar
    Jul 2009
    167
    Interesting, every time I download the Oly Updater, it says it is version 1.3, even if I see the 1.4 prior to the download. Tried the UK and the JP sites, same thing.... any ideas guys?
    Phil
    Photo-Matix Imagery - Capturing Life with a camera
    Panasonic Lumix GX8, Lumix G85, Lumix GX7, and various lenses.
    Gallery: http://photos.photo-matix.com.au
    Jul 2009
    167
    Hi Phil,
    I'm a bit confused what you're trying to do, so let me go through the required steps for you:
    - make sure you have a 'fully' loaded battery in your E-M1
    - connect your E-M1 with the USB-cable to your computer
    - power up the camera
    - check the LCD display)
    - select <Storage>, press <Ok> button
    - start 'Olympus Digital Camera Updater' (current version 1.06)
    - wait for the Updater to find your camera.
    - check the line with /Device/Model name/Current version/Newer version/
    - hopefully under /Newer version/ it reads <1.4>
    - be aware the highlighting might obscure the text (on my iMac it's a yellow/orange marking)
    - proceed updating ...
    i guess this is all familiar, my apologies, but perhaps we find the point where it goes wrong.
    Kind regards.
    No, no apology needed... I am still learning this camera, all suggestions are welcome... but...
    One difference is the PC vs Apple maybe? The steps I took were to get the latest updater, I had one from firmware 1.3 and it simply said there was no update needed.
    Went to the Olympus sites and downloaded the most current uploader, it was talking about firmware 1.4 etc, so I set the camera as you suggested, ran the updater... and it said the firmware was 1.3, nothing to do here....
    So, I do have the 1.3 firmware installed, downloaded the latest updater, on my computer is says the Updater.exe is todays date.. but then the firmeare it wants to update is 1.3... very strange.
    As noted, I had no problem updating from 1.2 to 1.3 only a month ago...
    Will try in the light of a new day I guess.
    Phil
    Godfrey's Avatar
    Jan 2009
    7,928
    Hey Phil,
    I'm on Apple systems, OS X v10.9.3.
    I used the Olympus Camera Updater v1.06.
    - Started the updater
    - put a freshly charged battery into the camera
    - connected the camera to the computer on Storage mode
    - updater recognized the camera; the updater showed it was running fw v1.3 and fw v1.4 was available
    - clicked the update button
    - ... waited a day and an age while the circle spun ...
    - finally the "installing" display appeared on the camera LCD
    - then the camera said OK
    - according to instructions, disconnected then powered off the camera
    - clicked the finished button in the updater and it quit
    Godfrey - GDGPhoto Flickr Stream
    k-hawinkler's Avatar
    Dec 2009
    The "Land of Enchantment"
    3,298
    Hey Phil,
    Thanks. Same here. Works like a charm.
    With best regards, K-H.
    Jul 2009
    167
    Quote Originally Posted by k-hawinkler View Post
    Damn and @$%$#@##, so that means I have to go and purchase an Apple computer.... haha... Will try today, maybe the PC updater had to filter through the system first. Thanks for the help folks...
    Phil
    Senior Member JMaher's Avatar
    Sarasota
    942
    16
    No problem on my Mac - updated and ready to test tomorrow.
    Knorp's Avatar
    3,993
    Quote Originally Posted by Matix View Post
    Phil
    Hi there Phil,
    sorry for chickening out: but I feared I was pointing out the obvious.
    I've been accused of patronising before ...
    As you noticed there seems to be a difference between the updater for Mac and PC.
    Also, as I mentioned in my initial post - at the time there was little to nothing to be found on the Olympus websites.
    Perhaps the PC updater you were trying to install was not yet 'updated' ?
    I'm sure it will work out alright.
    Kind regards.
    Bart ...
    Dec 2009
    3,298
    Hi there Phil,
    Kind regards.
    Firmware Update Instructions
    Jerusalem, Israel
    1,282
    On my PC, the updater is version 1.03, and it loaded 1.4 on my E-M1. It took longer than I expected. Perhaps because of a slow download from the web.
    scott
    Senior Member Elderly's Avatar
    Oct 2013
    UK
    262
    Are you trying to update via Olympus Viewer 3 on a PC?
    If so - go to 'Update' (top left of screen, 6th in) and click on 'update'.
    It then gives you the choice of 'Update Software' or 'Update Camera',
    choose 'Software' to check if you have the latest version.
    I've NO idea if it's at all relevant, but I thought I would mention it.
    Ian.
    Jul 2009
    167
    Quote Originally Posted by Elderly View Post
    Thanks Elderly, I seem to be doing the right thing but the Updater does not want to recognize the update. I for sure have the 1.3 version now, but it says it does not need to be updated.
    Here is what I get.
    And when I proceed with this downloaded EXE file
    Jerusalem, Israel
    1,282
    Those screenshots suggest that your updater is up to date, but don't say anything about your E-M1. Now start the updater, attach the camera with its Olympus USB cable and the update will be installed...
    scott
    Hampshire, UK
    904
    20
    Phil
    Once you have connected the E-M1 and set the camera to "storage" (don't forget to press the OK button on camera to activate your command) the update will provide the instruction right the way through to when you see OK on the camera LCD which can take up to 10 minutes depending on broadband speed.
    Just before the OK there will be a diagrammatic in colour on the LCD warning you NOT to disconnect the camera.
    After the OK sign you can disconnect the camera USB and switch off the camera. then switch it back on again and you will find that v1.4 is updated.
    Cheers, Dave
    Dec 2009
    3,298
    One got to be patient though. It takes a few minutes.
  19. #19
    Jul 2009
    167
    SUCCESS!!
    For whatever reason, the Updater would not work... So I took Elderly's advice and used the Viewer, also 1.3 which I had never installed before... it worked a treat. Dowload of firmware with no complaints from the PC, 2 min to download and 1.5 min to complete. Thanks to the speed of fibre internet...no pain, but it is a bit scary relying on a cable while it does this process, I much prefer the downloading of a BIN file to the card like Panasonic, but as long as it works.
    No idea why this time, the second since I bought the camera, I had problems... the Updater worked when going to 1.3 but it is done.
    Thanks everyone for the input, I thought I was losing the plot... but that is another story.
    Phil
  20. #20
    Dec 2009
    3,298
    SUCCESS!!
    Phil
    I am glad it worked for you, Phil.
    It's certainly a bit nerveracking to update that way.
    It's probably a good idea not to update the camera or a lens during a thunder storm. It seems this year we have an early start of the monsoon season here in the mountains of northern New Mexico. The rain is most welcome and urgently needed. But it's still best to unplug electrical equipment from the power grid when the lightning and thunder gets closer.
  21. #21
    Hampshire, UK
    904
    20
    Well done Phil, I am pleased that you have it it sorted OK. It is a bit scary and I also prefer the Sony and Panasonic method of updating firmware, but whichever way it is very satisfying once you have completed the procedure!
    Cheers, Dave
  22. #22
    Mar 2011
    Michigan
    11
    I got a nice surprise when I updated my EM-1. Had my 50-200 attached and saw that an update was available for the lens.
  23. #23
    Godfrey's Avatar
    Jan 2009
    7,928
    Quote Originally Posted by gib48189 View Post
    Hmm. Which version 50-200, original or SWD? I should check with all of my lenses...
    Senior Member kweide's Avatar
    Germany
    1,631
    The actual Version for Zuiko 50-200SWD is 1.1
    There is no new version available
    __________________________________________________
    Part of the Wonderland
    see more ( NSFW ) on : http://www.klaweide.de
  25. #25
    Mar 2011
    Michigan
    11
    It is the 50-200 original, as Kweide notes it may not be new, but I never had the lens connected to a cam when updating so it was new to me. It was version 1.1, I am also going to check the rest of mine, who knows how far behind I might be. Won't be the first time..
  26. #26
    Godfrey's Avatar
    Jan 2009
    7,928
    You can see all the current lens firmware revisions here:
    Joint update service for OLYMPUS E-SYSTEM - OLYMPUS Digital Camera
    It's easier to just mount the lens and see what firmware revision is showing than to connect and reconnect, etc, for each one with the updater. I think I'm all up to date, but I'll check them out. :-)
