Results 1 to 8 of 8
Thread: multi shot for upscaling
    Jan 2013
    1,173
    I need to print one of my images to 60x48
    However the subject matter is only reachable using a 400mm lens, currently I can only reach that using my m4/3 system.
    I'll need to upscale anyway but want to start with as much pixels as possible.
    Which is a better technique through multishot?
    1- take the same image multiple times and blend in Photoshop
    2- zoom in further, and take multiple shots of the different portions of the image, then blend into panorama in photoshop.
    any thoughts on which would give more resolution in the final image?
    Jan 2013
    1,173
    Re: multi shot for upscaling
    solved it. zoomed in and took portions of the shot
    Sep 2011
    Devon, UK
    286
    Quote Originally Posted by mmbma View Post
    That's what I would have suggested if I'd seen your original post, before you answered your own question...
    I must admit, though, that I didn't really understand Option 1 in your post.
    Jan 2013
    1,173
    Well do you remember those Multishot digital backs? They took multiple shots of the same image and produced more resolution.
    I wonder if we could do the same in photoshop or some other blending software
    Mar 2010
    Southampton
    565
    I have wondered about this as well. Since we're dealing with photo sites of ~0.005mm, even with two successive identical shots of the same scene, the sensor is almost guaranteed to have been displaced by this amount or more (e.g. just via shutter vibration).
    Might there be a way in software to take the image data from 2 or more 'identical' images from a standard DB (i.e. not a HB MS one, which is obviously designed to do this) and combine them to get a higher res image, or one with non-interpolated color, or both?
    Jim
    Jul 2009
    Swiss Alps
    1,444
    3
    I think that this technique was used to mitigate the noise and thus get more resolution. Nowadays that sensors are better, it would only bring more resolution if you are shooting at high ISO. But you didn't tell anything about light conditions.
    Stitching shots as you did was probably a more effective way to increase resolution.
    Workshop & Subscriber Member manouch shirzad's Avatar
    Dec 2009
    NY, NJ, United States
    133
    10
    "Photoacute" does a great job. You need at least four images to do that.
    Best,
    Manouch
    Jan 2013
    1,173
    thanks! will try that out
