Results 1 to 14 of 14
Thread: G1 attached to my Leica Televid 77 Spotting Scope
    Los Altos, CA
    10,486
    1031
    So my Leica capera adapter came, and while I'm still waiting on my T mount to 4/3rds adapter, I realized I had a T mount to Nikon, and a Nikon to 4/3rds, so I was able to cobble it all together for some initial -- very initial -- testing.
    First off, there was some play in the 4 mounts used, plus I need a better plate for the scope, and admittedly I was too lazy to get my larger tripod out as it's packed for Moab. Plus it is a gray, overcast day, so not a lot of light. Anyway, no doubt this set-up can do a bit better, but here is an very early shot just to try it out.
    First the set-up. Note the 4 adapters from scope to camera; Leica scope to T mount, T mount to Nikon F, Nikon F to 4/3rds, 4/3rds to G1:
    Next, the scene as it appears shot with the G1, kit lens set to normal or 25mm. The hose on the house across the street is about 50 meters away:
    Next, the full frame on the G1, same shooting position as above as seen through the scope, straight from the camera:
    Finally, here is an actual pixel crop from the above image. I realize it isn't super sharp, but then I don't know what sharp from a 1000mm tele on the G1 is supposed to look like:
    Anyway, I think it shows some promise, so stay tuned for more to come AFTER Moab and after I get the T to 4/3rds adapter.
    home: www.getdpi.com
    Senior Member DavidE's Avatar
    Mar 2008
    1,216
    Re: G1 attached to my Leica Televid 77 Spotting Scope
    Cool.
    Can't help but notice that your G1 lens setup resembles your outside plumbing.
    Los Altos, CA
    10,486
    1031
    Fortunately, that's my neighbor's outside plumbing, not mine
    Lupo
    So my Leica capera adapter came, and while I'm still waiting on my T mount to 4/3rds adapter, I realized I had a T mount to Nikon, and a Nikon to 4/3rds, so I was able to cobble it all together for some initial -- very initial -- testing....
    In Germany I would have long been arrested.
    either because of the telescope in the neighborhood,
    or of the crooked pipes.
    Lupo
    Oh, sorry
    Los Altos, CA
    10,486
    1031
    I just realized this is actually an 1100mm f10 lens when used this way, so equivalent to about a 2200mm effective tele on the G1(!)
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,778
    Quote Originally Posted by Lupo View Post
    Oh, sorry
    Don't apologise - he's only saying that - it is his plumbing really . . . . you can tell because, as David pointed out, it looks so much like his camera setup!
    Just this guy you know
    Jan 2009
    281
    The Street Shooter's Dream!
    23,623
    2555
    I hope you put that thing away at night.
    www.guymancusophotography.com
    Senior Member Y.B.Hudson III's Avatar
    Jan 2008
    314
    yehh, Jack...your neighbor needs a back-flow prevention devise on his irrigation system...
    Subscriber Member Chuck Jones's Avatar
    Studio City, CA
    700
    18
    You, my friend, are a MAD MAN!
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    Awesome set-up! The Televid is as heavy or heavier than some of the 1000mm mirror lenses.
    olyinaz
    Exactly Jack! Don't apologize at all for that image quality!
    At any rate, unless the Leica is advertised as having a flat field at the focal plane (not common) you can probably improve upon your image quality at the corners and gain a bit of extra speed by using a focal reducer/field flatter in the image train. I know that Tele Vue makes a .8 model that gets good reviews and also William Optics has one. The key is to get one that's optimized for the focal length of your scope.
    Oly
    Pratamnak
    9,331
    2157
    Hmmm... should I consider this for street photography? Jack, can you do me a favour?
    Take a stroll through the city with this setup mounted on a BushHawk, and see if you get arrested
