Results 1 to 17 of 17
Thread: Novoflex M adapter recall?
    Nov 2008
    3,848
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Re: Novoflex M adapter recall?
    If Jono remembers, I predicted this!
    Novoflex' adapter is a rehash of their old one (an LTM to M adapter- no infinity focus on it though, I forget the code name for it). They just put the m4/3rds mount instead of the LTM mount. Even the replacement wouldn't cut it (for me), I am sorry to say.
    RayQual thought of all the problems and to date remains the best designed m4/3rds to M adapter.
    Aug 2008
    Memphis, TN
    89
    Monza:
    Thank You for the heads up... I bought a Novoflex adapter two weeks ago I will check the lens on my M8 to see if my focus is out
    Is Mr. Nemeth saying that the rear of the lens, in this case Nokton, rubs against adapter and knocks the calibration off?
    Robert.
    Nov 2008
    3,848
    The description of the problem starts at post #108 ('problem 2'):
    http://www.rangefinderforum.com/foru...t=68082&page=3
    Senior Member Per Ofverbeck's Avatar
    Feb 2008
    503
    5
    I noticed this at once when I got my adapter. Since the EXACT register distance for MFT seems to be a trade secret (I Googled, and ended up with a document stating that the specs were available to manufacturers taking part in the MFT cooperation), I kind of expected Novoflex to stay slightly on the safe side - but certainly not that much...
    I did mention my concerns in another thread about hyperfocal distances
    ( http://forum.getdpi.com/forum/showpo...82&postcount=7 ),
    but nobody else responded at the time.
    For me, this adapter is the "key" to everything else: Ive got Nikon F-to-M and Leica R-to-M adapters, as well as the usual LTM-to-M one. So, if I return it, Ill be without all lenses except the kit ones.... I dont really think Ill do that; after all, it is a minor nuisance.
    Nov 2008
    3,848
    I assume that this would be caused by an adapter that is too 'thin', so to speak?
    Aug 2008
    Memphis, TN
    89
    "The biggest problem (other than rendering the lens markings useless) is that the lens achieves its field of focus over a much narrower rotational angle. This gives you fewer degrees of rotation per change in focus, which makes focusing a little bit more difficult than it would normally be. Sometimes, just a tiny little nudge to the lens will throw the focus WAY off, rather than changing it subtly. In my focus tests, everything from 4M to beyond 10M was focused within a range of 2M-3M on the adapted Nokton."
    Above is the quote From Mr. Nemeth.
    I read too much in between the lines and made some crazy assumptions. My fault for overreacting. Basically it is a nuisance and incorrect calibration rather than by using the Novoflex adapter, it will damage your Leica lens... Phew! Got me extremely worried... but I will continue to look for another adapter that will allow hyperfocus and will exchange for a newer Novoflex when I get another M-m4/3 adapter.
    Robert.
    Feb 2008
    503
    5
    Yep, the adapter is slightly too thin. This ensures that the lenses will actually be able to focus to infinity (and somewhat beyond). With a normal focussing helicoid, the error will be a constant *angle* (in fact, it should be possible to find and memorize a new "infinity index" somewhere on the DOF scale of the lens (different for different focal lenghts, of course). That same angle error is whats lost in close focussing capacity; not very much. But the infinity stop (or lock on some Leica lenses) isnt correct.
    In no way will the lens itself be changed or damaged by this. It will work just as before on its "native" camera bodies.
    (About that "secret" register distance: on a film body, it would be easy to measure it directly, with good measuring instruments. But the sensor surface is hidden behind the dust shaker glass, the IR and anti-alias filter, microlenses &c., and there just isnt possible to measure it directly. So if it isnt public, any 3rd party adapter maker will have to use trial-and-error methods.)
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    m4/3rds camera registry is 19mm. If I had a working Vernier calipers, I would be more precise.
    Brooklyn
    4,043
    1253
    I have considerable measuring equipment at my disposal, yet it is virtually impossible to directly measure the flange to focal plane distance due to covering layers on the sensor, etc.
    with my adapters, i made a few trial versions, mounting a long focus lens and verifying that at the infinity setting of the lens, focus was just achieved. I went a bit past it just to make sure. that manual focus magnifier on the G1 was ideal.
    I also made a few trial versions of the M to G1 adapter, but am now modifying the design to accommodate the slight variation among lenses. The newer version will have a leaf spring to hold the lens tightly against the adapter (same as the Lecia method) and be made of black anodized aluminum with a larger lens release button
    Senior Member barjohn's Avatar
    Galveston, TX
    947
    171
    If you look at the top left plate of the camera the sensor plane is clearly marked. I have also seen the exact specification published. I will look for it and post it when I find it.
    P.S. That explains my earlier post where I said the distance scale appeared to be incorrect and everyone said no it wasn't. I had the Novoflex adapter. I guess I need to get it exchanged.
    V/r John
    Galveston, TX
    947
    171
    Ok, the DPReview review has a cutaway drawing showing a comparison between 43 and M43 where M43 is shown as 20mm flange to sensor and 43 is 40mm flange to sensor.
    V/r John
    40
    The register can be easily determined by examining the DMW-MA1. Since 4/3rds register is known (38.67mm) and the MA1 is measureable, m43's register can be determined via that route.
    IIRC it has been done and determined to be 19.25mm register.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Quote Originally Posted by mawz View Post
    In addition (to the DMW adapter), actual projection of the kit lens could be used, as well as lenses from other manufacturers where accurate infinity calibration is available to cross check.
    Yes, 19mm (plus something) sounds like the real thing. The images John posted give an average measure (for illustration of the new system) and aren't accurate figures.
    Nov 2008
    3,848
    Got a reply to my inquiry to Novoflex:
    "Please send us the MFT/LEM back.
    In a few days well get the new ones out of production. Then well ship you one of these adapters.
    Im sorry for any inconvenience that this delay will cause."
    Senior Member Hacker's Avatar
    Cyberspace
    383
    I heeded your advice and got the Rayqual. *Phew*
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Glad it worked out for you.
    Since I toiled to make one by hacking pre-existing mounts and adapters (my adapter is more expensive than the RayQual, btw), I could recognize the potential problems and the workmanship that went into the RayQual adapter.
    You can be sure that your Noctis would be safe with that one.
