Here's what I hope will be a 100% crop from the fence wire shot, Which I understand was rendered in camera as a super fine resolution jpeg after taking one of the magic 40 MPx shots with the E-M5 II:
What I see on my editing display is a white area surrounding each of the wires, horizontal, vertical or hexagonal. Let's see if works in web display.
scott
Hi Scott, many thanks indeed. I am marveling at your excellent eye sight and skillful observations.
Of course, you have correctly identified the white areas surrounding each of the wires, horizontal, vertical or hexagonal.
I can see them now as well.
Before I got fooled by some transient display feature of smugmug that has nothing to do with the phenomena you have described.
Enough of that though.
What I have done is look in detail at the following 4 images and extract 200% 1024x1024 crops.
Here they are:
• OOC JPG
• This image is derived from the high res .ORF file with CS6 and the Olympus plugin.
• Apparently some sharpening is baked into the plugin.
• No further processing
• This image is derived from the high res .ORF file with Iridient and sharpening applied by Iridient
no sharpening applied.
- I have also tried the Olympus Viewer 3. But it cannot display correctly yet a hi res image with full resolution.
So it appears sharpening has something to do with the white features you have pointed to.
Thanks again for being so accurately observant and pointing it out. Thank you.
PS: I took then the last unsharpened image and sharpened it with Nik. Also enhanced contrast a bit.
The full resolution image is here:
http://winklers.smugmug.com/2015-02...dient_7296x5472_unsharpened_Nik_sharpened.jpg
Scott, please let me know if you can see any of the white stripes. TIA.
