Page 6 of 14 FirstFirst ... 4 5 6 7 8 ... LastLast
Results 251 to 300 of 673
Thread: G1?...we don't need no stinking G1/Picture thread
  1. #251
    Senior Member f6cvalkyrie's Avatar
    Feb 2009
    Belgium
    1,643
    29
    Re: G1?...we don't need no stinking G1/Picture thread
    Very nice work, Klaus !!
    C U,
    Rafael
    E-M1/GH2/G1 Full Spectrum & lots of lenses
    http://www.flickr.com/photos/f6cvalk...th/9226689839/
  2. #252
    Senior Member kweide's Avatar
    Germany
    1,631
    Lost in the tree, in 10 meters height...
    Done with the old Zuiko 40-150 fully opened at f3.5
    __________________________________________________
    Part of the Wonderland
    see more ( NSFW ) on : http://www.klaweide.de
  3. #253
    Senior Member m3photo's Avatar
    1,043
    28
    OK kweide own up! I remember a previous poster asking you to tell us all how you make your images stand out they way they do. He asked another question which you kindly replied to but somehow missed this one ...
  4. #254
    Germany
    1,631
    Uh, what a bad boy i was. Really ??
    Okay, but is not a miracle again it is just some minor PP to get the details and colors pop.
    To make it easy: It is the Oly colors....
    No, indeed not !
    Adobe Photoshop is the base but you can do the tuning with any SW you like.
    Please note: No longer PP than 2 Minutes ! Everything longer is boring.
    Here we go:
    I assume, WB is correct and exposure is OK. Check histogram CTRL L and make your correction.
    In case of strong noise ( one never knows ) use a noise removal tool FIRST. This is important. Noiseremoval tools can change the appearance of the picture
    Set Contrast to a higher level. Normaly in CS3 something around +30. If it gets too dark in the shadows choose less.
    Set Saturation to a higher level. This a little tricky. Too much saturation and it looks like a cheap plastic bag from Walmart. In CS3 you can alter saturation combined over RGB channel or you can change colors seperatly. Depends on your taste. Normaly saturation may not exceed the additional contrast level.
    Check whether the picture needs a little extra exposure. Be careful in adding additional values. Max 0.1 to 0.2 should be enough ( Picture Menue, exposure )
    If you now compare this stadium with the starting picture you will see enormous differences. Okay, now the big points:
    Sharpen your image with USM. My settings for E-3 are: 150 / 0.8 / 0. Play with the values. Different cams needs different settings. Use mine as starting point.
    You will see: suddenly the complete image gets more pop.
    Resize the picture to Websize. I always set the longest side to 1000 pixels.
    At this point i do my frame and nametag.( The white border )
    Due to resizing the picture loose clarity. Use the SHARPEN command in CS3 in the Filter Menue. It has no parameters to go. Just choose and hui... the details pop again. Sometimes it is better NOT to do the second Sharpen. You will easily see it. When ugly artefacts occurr step back. And leave it as it is.
    (Hardcore solution: 2nd USM with differnt settings... )
    That is my easy to follow wrap up. If you do not have CS3 or whatsoever Adobe SW:
    Download IRFANVIEW. It is a great pictureviewer and a great tool to make easy adjustments. Contrast and saturations are chooseble and under Image/Effects/effectbrowers/ you will find an excellent USM sharpener. On large files choose 3 or 4 max.
    My aim was: Let the details pop. I hopefully achieved this mainly with a little more contrast, saturation and a 2 stage sharpening.
    Yes, there are a lot more possiblities: Color Lab adjustment, special filters and all that stuff. I dont use any addditional filter except for Noiseware.
    Mostly....
    Klaus
  5. #255
    Germany
    1,631
    Another easy way to make it pop
    Works in Photoshop
    1. Make a backgroundcopy of you picture.
    2. While Background is active select "Soft Light" in the drop down Menu of Layers
    3. Choose on the Top Menue of PS Filters Other Highpass and choose the max Value. Enter OK
    4. If it is too much reduce Opacity to something about 50% ( Layer menu )
    5. Still too much sharping ?? Add a Layer Mask, choose a appro. brush to simple BLACK draw those parts away....
    Is it OKAY for you ???
    I am not the PP Specialist... just a bloody amateur
    Klaus
  6. #256
    1,043
    28
    Thank you Mr. B.Amateur
    Quote Originally Posted by kweide View Post
    Klaus
    I'm sure many will be most appreciative of your detailed explanations and I thank you on their behalf and mine.
    I have been using High Pass Sharpen for a good while now and I recommend it for those shots where noise is a problem with other sharpening methods. Setting the Layer Style to Hard Light accentuates the effect if Soft Light at 100% still isn't considered enough (usually for scanned negatives, this one).
    I'd like to add that one PS command that is frequently shunned by diehards but really is an ideal starting point as a tell-tale sign that the image needs initial correction is Auto-Color - apply on a copy of the background layer and switch on and off to check the difference; in many cases "Auto-Color" is right and you're wrong!
  7. #257
    Germany
    1,631
    Heading: Harbour
  8. #258
    Jan 2009
    Baltimore, Maryland USA
    466
    I just received my "factory demo" E3 a few hours ago, and lucky for me it is pouring rain (the very reason I bought it)!
    Some hasty pics of a local abandoned school before it gets dark ...
    Attachment 14894
    Attachment 14895
    Attachment 14896
    Me likey so far....
  9. #259
    Germany
    1,631
    Well done Scott.
    Congratulations !! But keep away from that nasty Oly-Glass.
    Zuiko 150 F2 is what i am looking after now Dont tell my wife...
    Klaus
  10. #260
    Jan 2009
    466
    Klaus,
    I won't tell your wife if you won't tell my lovely significant other about my lust for an Oly 12-60....
    Let's discuss over coffee.
  11. #261
    Germany
    1,631
    Scott,
    ... promised
    and a snapshot from todays travel. Zuiko 7-14
  12. #262
    Germany
    1,631
    8 Picture Pano-stitch from todays travel. Again Zuiko 7-14
  13. #263
    Jan 2009
    466
    Wow! Spectacular...
  14. #264
    Feb 2009
    Belgium
    1,643
    29
    lovely shots, Klaus
    Rafael
  15. #265
    Germany
    1,631
    Another two from yesterdays travel...
  16. #266
    Germany
    1,631
    Turrets, from yesterdays travel...
  17. #267
    Michiel Schierbeek's Avatar
    Mar 2009
    Amsterdam/Normandy
    4,055
    762
    Quote Originally Posted by m3photo View Post
    Just got back from France.
    Yes, yes that was me asking that question. I thought it may have been an impertinent one. But you got an answer! You got the authority.
    BTW for sharpen I always use unsharp mask in CS3. Gives you more control.
    Thanks Klaus for the insights. Liked your series with the buildings and the freightliner.
    Regards, Michiel
  18. #268
    Germany
    1,631
    On the other side: no turrets but some nice reliefs
  19. #269
    Feb 2009
    Belgium
    1,643
    29
    Excellent pics, Klaus, but, WTH have you been ????
    I see the onions of russian cathedrals, but no further reference to anything from there ???????
    Pleeeeaaaasse, tell us
    Rafael
  20. #270
    Germany
    1,631
    Where i have been ???? Where i am ???? What is life all abaout ???
    It was done on two locations.
    1. Schwerin in Mecklenburg-Vorpommern in Germany. Schwerin is preparing for an exhibition, the BUGA. See details here: http://www.buga-2009.de/ and more about Schwerin http://www.schwerin.de/.
    2. Ludwigslust. About 30 car-minutes away from Schwerin.More Details you find here: http://www.stadtludwigslust.de/porta..._schema=PORTAL
    Both locations can be done within 1 - 2 days. In Schwerin there is a lot more to look at: The castle, the Pfaffenteich, the cathedral, the park, the sea. You will need 1 day alone for Schwerin. Have to post more pics...
    Ludwigslust has this little castle with beautiful arts inside. Gold plated ornamentation which are made of paper maché. A must see. The park, the fantastic town church again with paper maché work
    Have a look and have fun...
    Klaus
  21. #271
    Germany
    1,631
    Windows of a Kindergarten...
  22. #272
    Germany
    1,631
    White toamtoesoup.... hmmmmm
  23. #273
    Germany
    1,631
    Second plate... whatever you like
  24. #274
    Germany
    1,631
    The last plate
  25. #275
    Senior Member helenhill's Avatar
    NYC
    1,895
    16
    KLAUS
    I'm STARVING!!!!!
    Shall we meet up for Dinner another night....
    Cheers....You Lucky Devil
  26. #276
    Germany
    1,631
    Helen...
    very good taste indeed....but Gotham City is too far away from my location .... that makes me a little sad but offers me an additional plate of that fabulous white tomatoesoup...
    Klaus
  27. #277
    Mar 2009
    Amsterdam/Normandy
    4,055
    762
    If you are in need of a car, there are plenty coming in!
  28. #278
    Germany
    1,631
    Yes, we are open.
  29. #279
    Germany
    1,631
    Helen,
    this is for you, some sweets for our night......
  30. #280
    Mar 2009
    Amsterdam/Normandy
    4,055
    762
    Some cardelights!
    All with 35 mm 3.5 macro exept the third with Sigma 24mm 1.8
  31. #281
    Germany
    1,631
    Yesterday in the evening the devil came in to me... talking sweet words and gave me a Nikon D700 and some glass... just try it out....uhhhhhh what a temptation....is it really that good... jump ship...selling all Oly stuff ?? Unsure... Devils words soooo sweet.... unsure.... HELP...........
    (This pic done with Oly )
  32. #282
    Subscriber Member Georg Baumann's Avatar
    Feb 2008
    787
    82
    Nope. Keep Oly and wait until 7xyz with big sensor hits shelves.... then go and test it.... if as good as imagined.... sell devil!
    Seriously though, I think there are three reasons to keep the Olympus. 7-14mm, 50-200mm and last not least the 50mm. In my view a fantastic performing set of lenses for very reasonable money, within the limitations of the Oly of course, but that we know since long.
  33. #283
    1,043
    28
    Re: The Devil
    Does he do house calls in Spain? Tell him I've got 16/24/35/50/55/105/135/500mm Manual Nikkors for it!
  34. #284
    Feb 2009
    Belgium
    1,643
    29
    Did she wear Prada ???
  35. #285
    Germany
    1,631
    Boy, what a temptation. Oh no that devil did not wear Prada...
    Did she wear someting ??? Yes, see here:
    Sorry for the bad quality... so exhausted.....
  36. #286
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    Where the devil is her picture?
    -bob
  37. #287
    Germany
    1,631
    Sorry Bob, can´t take a picture now...i´ve got my hands full....
  38. #288
    Germany
    1,631
    Well, so i helped my neighbor to start this little rocket
  39. #289
    Germany
    1,631
    They look strange...
    Catch the Fly
    So alone...
  40. #290
    Mar 2009
    257
    Just stumbled across this "beauty" what is actually just weed in my garden.
  41. #291
    wblynch
    Feed Me, Seymour !!!
  42. #292
    Germany
    1,631
    Mother nature... always a surprise
  43. #293
    Germany
    1,631
    Give me a little attention and love...
    Zuiko 7-14, ISO 1000
  44. #294
    Germany
    1,631
    Still too fast ...
  45. #295
    Germany
    1,631
    E-3 is fast enough...
    Blown in the wind. 1st try
    Blown in the wind. 2nd try
    Blown in the wind. 3rd try
  46. #296
    Germany
    1,631
    Blown in the wind.
    4th and last try....
    WOW, that was great fun, playing around with that blowballs like children. And the dog went crazy
  47. #297
    Senior Member Brian Mosley's Avatar
    Jan 2008
    2,394
    17
    Lovely Klaus, thanks for sharing!
    Cheers
    Brian
  48. #298
    Germany
    1,631
    Uhhh, what a bad day.
    Got those really red and swollen eyes thru pollen allergy ....
  49. #299
    Senior Member kevinparis's Avatar
    Jun 2008
    919
    5
    hi
    been quiet for a while... but thought i should make an appearance and thank klaus for all his effort in keeping this thread alive
    here a couple of shots where i have tried some of the zen masters ancient art of Zing
    first in a recent from oly510 with a 35mm takumar
    second is an old shot from a canon 10D
    cheers
    K
  50. #300
    Germany
    1,631
    Good to see you back, Kevin. Now it is time for you to put on the iron gloves
    put on your helmet
    for the bow take the arrows
    and fight your way against G1. In the meantime i will take away the princess...
    No Bob, this is not for you....
