Page 4 of 7 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 151 to 200 of 306
Thread: My DMC-G1 with manual focus lenses
  1. #151
    Gothenburg, Sweden
    1,309
    Re: My DMC-G1 with manual focus lenses
    Quote Originally Posted by butterdada View Post
    Infinity of my D.O. Industries Navitron TV 75mm F1.3 is ok
    No need fot modification~
    Hmm. Now I really would like to get one and try it. What adapter (seller) are you using with the lens?
    /Jonas
  2. #152
    butterdada
    Quote Originally Posted by Jonas View Post
    /Jonas
    New generartion (3rd) C to M4/3 adaptor made by Hawk factory, Taiwan
    Lomo OKC2-100-2 100mm F2.8 wide-open
    modified by Hawk Factory
  3. #153
    butterdada
    Minolta G-Rokkor 28mm F3.5 (L39 mount)
    I used adaptor made by RJ camera (from China).
  4. #154
    Gothenburg, Sweden
    1,309
    OK. Cheers, /Jonas
  5. #155
    butterdada
    OK. Cheers, /Jonas
    Do you have Hawk's email?
    Here.
    [email protected]
    He is a nice guy.
    Elgeet Rochester 1 inch F1.9 wide-open
  6. #156
    butterdada
    Canon FD 135mm F2 wide-open
    This FD to M4/3 adaptor is made in China (RJ camera).
  7. #157
    Mar 2009
    90
    No need for modification~
    Hi, butterdada. I was confused, I really tried hard to reach the very end of the infinity.
    How comes the rear element just touch the square part in front of the sensor?
    I am using jinronfinance's adapter, is it the main problem? I still doubt about it.
    But there is already a press mark on the square part.
    May be the screw thread not exactly in the center. Really headache......
  8. #158
    Senior Member Y.B.Hudson III's Avatar
    Jan 2008
    314
    ... it's the lens design that's the problem, not the adapter. ask butterdada if his copy of the Navitron 75mm 1.3 can focus to infinity at f/1.3 (which I doubt)...the picture he posted is stopped down.
  9. #159
    Mar 2009
    90
    Quote Originally Posted by Y.B.Hudson III View Post
    Yes, that's what I doubt . F5.6 start to get sharp, F8 seems no problem.
    I have compared the image between out and in focus at F1.3 that the
    image present quite different. F1.3 produces soft image but not out focus blur.
    You may see this picture. I turn the lens to infinity and you can see rear element.
    The metal ring seems quite thin and need extreme care. I think 0.5mm trimming may be enough to make the thing totally different.
  10. #160
    Jan 2008
    314
    You have to remove the metal ring and then it is possible to glue the rear Lens element in place...as it is retained on the sides by the lens barrel and there is a spacer insert to seat the element square.
  11. #161
    butterdada
    Yes
    I tried a F1.3 infinity shhot.
    Very soft , but I think the focus is ok.
    local full size
  12. #162
    butterdada
  13. #163
    butterdada
    Carl Zeiss Jena DDR Tevidon 25mm F1.4 wide-open
    This lens needs modification.
  14. #164
    Gothenburg, Sweden
    1,309
    Lol, that's taking the Cat's Eye Effect to an extreme...
  15. #165
    butterdada
  16. #166
    butterdada
  17. #167
    butterdada
    Carl Zeiss Jena DDR Tevidon 35mm F1.9 wide-open
  18. #168
    butterdada
    Canon FD 85mm F1.2 wide-open
  19. #169
    butterdada
  20. #170
    Gothenburg, Sweden
    1,309
    Yes
    I don't know... To me it seems as it doesn't focus to infinity looking at this image. For example, to the left you have the terrace with a fence (if fence is the correct term, maybe it is a wall?) on it. It seems to be sharper somewhere in the middle of the image than in the distant parts, and that with pretty much similar distances between the fence and the middle of the sensor.
    To me that would be no problem as I wouldn't use a lens´like this for landscapes wide open. If distant stuff can be reasonbly sharp with the lens stopped down it is good enough.
  21. #171
    butterdada
    Canon FD 85mm F1.2 L
  22. #172
    butterdada
    Kinoptik Tegea 9.8mm F1.8
  23. #173
    Senior Member petermcwerner's Avatar
    Jan 2009
    Geneva, Switzerland
    511
    butterdada, what mount is this lens and what adapter do use for it?
    Peter Werner
    Leica M8, R9+DMR & Digilux 2; Nikon D700; Panasonic FX01, FX150 & G1; Samsung TL350 (WB 2000)
  24. #174
    butterdada
    Quote Originally Posted by petermcwerner View Post
    My friend Hawk modified it to Nikon mount. Then I used Nikon-to-4/3 & 4/3 to M4/3 double adaptor.
    Canon 100mm F2 L39 mount wide-open
  25. #175
    Jan 2009
    Geneva, Switzerland
    511
    Thank you
    Peter Werner
  26. #176
    butterdada
  27. #177
    butterdada
    Leitz Elmar 50mm F3.5 wide-open
  28. #178
    butterdada
    Leitz Summaron 35mm F3.5 L39 mount wide-open
  29. #179
    butterdada
  30. #180
    butterdada
  31. #181
    butterdada
    Leitz Elmar 50mm F3.5 全開
  32. #182
    butterdada
    Cooke Speed Panchro 40mm F2
  33. #183
    butterdada
  34. #184
    butterdada
    Contax G Bigon 21mm F2.8 modified to Leica M mount
  35. #185
    Nov 2008
    3,848
    Butterdada, the edge performance of the Biogon appears to be very good from these web images, with the possible exception of this one. What is your experience in this regards with the full size images?
  36. #186
    butterdada
    Some edges of the pics showed color changes.
    It should be dark-angle in FF or R-d1s, not in M4/3 system.
    I think it might be the biogon structure related.
    Actually, its performance is really good enough.
    I can show you more pics.
    Contax G Biogon 21mm F2.8 + DMC-G1
  37. #187
    butterdada
    Voigtlander Ultra Wide Heliar 12mm F5.6
  38. #188
    butterdada
    Lomo OKC1-100-1 100mm F2
  39. #189
    butterdada
  40. #190
    butterdada
  41. #191
    butterdada
  42. #192
    Senior Member RonSmith's Avatar
    May 2009
    Michigan USA
    432
    Wonderful pictures, Butterdada!
    My G1 is going to be delivered today and I have a Voigtlander adapter that should arrive later this week. I can't wait to get out with my collection of Leica glass!
    Ron
  43. #193
    butterdada
    HaHa. But I think Epson R-D1(s) is the best choice for M mount lens.
  44. #194
    butterdada
  45. #195
    butterdada
    Contax sonnar 180mm F2.8
  46. #196
    butterdada
    Rollei HFT 40mm F2.8
  47. #197
    butterdada
  48. #198
    butterdada
    Kern Switar 50mm F1.8
  49. #199
    Senior Member m3photo's Avatar
    1,043
    28
    Love the cowboy sprinkler installation!
  50. #200
    butterdada
