Page 12 of 14 FirstFirst ... 2 10 11 12 13 14 LastLast
Results 551 to 600 of 666
Thread: E-M1, E-M5, E-M5.2, etc. ... Peculiarities
  1. #551
    k-hawinkler's Avatar
    Dec 2009
    The "Land of Enchantment"
    4,289
    Re: E-M1, E-M5, E-M5.2, etc. ... Peculiarities
    Page 112 of the E-M1 Mark II Instruction Manual:
    AF Focus Adj.
    Focal location adjustment for phase-difference AF can be fine tuned within a range of ±20 steps.
    With best regards, K-H.
  2. #552
    Knorp's Avatar
    5,267
    Quote Originally Posted by k-hawinkler View Post
    AF Focus Adj.
    K-H, just a thought: I made the adjustments indoors. Could that have triggered PDAF ?
    Anyway, when I find some time I'll look for the test shots as I still should have them on disk (somewhere).
    Kind regards.
    Bart ...
  3. #553
    Dec 2009
    4,289
    Shutter Count
    https://www.dpreview.com/forums/thread/4258152
    Guy Parsons • Forum Pro • Posts: 28,477
    Re: Shutter Count on OMD EM-1 II
    In reply to Colin Smith1 • 1 min ago
    Colin Smith1 wrote:
    Anyone who can give me good step by step instructions for the EM-1 II? I tried using instructions for EM-1 and they don't seem to work? Thanks.
    -- hide signature --
    Colin Smith
    My old page seems to hold true for all M4/3 Oly.
    http://homepages.ihug.com.au/~parsog...shotcount.html
    To save time and your clicks I'll paste the method here.....
    ► Camera OFF
    ► Hold down MENU button and turn ON the camera
    ► Release MENU button and press MENU again to get to Menus
    ► Go to LCD Brightness Menu, that's in Spanner/Wrench Menu.
    ► Press RIGHT to show screen adjusters
    ► Press INFO and then press OK and on my E-PL1 this shows on screen....
    OLYMPUS E-PL1
    04 01 01 01
    ► Press in sequence UP/DOWN/LEFT/RIGHT/SHUTTER/UP and Page 1 info appears
    ► Variously then press RIGHT for Page 2, DOWN for Page 3, LEFT for Page 4 and UP again to get Page 1
    What we are looking for is the information on Page 2, on my E-PL1 it shows (in earlier days).....
    R 002947 [total shot count, includes electronic shutter] - [E-M1 Mk2 shows MS for this item, and is mechanical shutter count only]
    S 000194 [shot count with flash]
    C 000000 [unknown]
    U 001493 [ultrasonic wave cleaner count, equals turn on count plus pixel map count] -[may have changed count usage with E-M1 Mk2]
    V 000000 [unknown]
    B 002396 [total shot count using in-body stabilisation (IBIS)]
    L 000000 [unknown]
    On Page 4 is D: which is the damage code log, mine shows nothing and that is good. [E-M1 Mk2 shows 100% for this item, presumably if all is OK]
    Power off to reset the camera back to normal.
    Hope that helps.
    Regards.... Guy
  4. #554
    Dec 2009
    4,289
    http://www.fredmiranda.com/forum/top...495/0#14376529 quote:”
    Where did you read about the C-AF being updated? There is nothing about it in the text about the update and all I've heard about it before has been mostly rumours or wishes.
    I saw it on an Olympus page which I think has been removed now:
    - New art filter [Bleach Bypass] has been added.
    - Possible to use focus stacking photography with "M.ZUIKO DIGITAL ED 12-100mm F4.0 IS PRO".
    - Small targets have been added to AF target mode.
    - Possible to set a maximum of 35 pre-shutter frames for Pro Capture shooting.
    Display has been improved to show that Pro Capture shooting is recording.
    - "Flicker Scan" has been added so it is possible to reduce flickering by fine adjustment of shutter speed while looking at the live view when using electronic shutter.
    - Fisheye compensation photography has been added for use of M.ZUIKO DIGITAL ED 8mm F1.8 Fisheye PRO. You can view the effects in live view while shooting images.
    - Possible to set zoom ratio during playback. Also, added pixel equivalence display to zoom ratio.
    - Pro Capture shooting is available for additional lenses.
    - Display of remaining battery power has been improved.
    - Response when assigning AF to AEL/AFL button has been improved.
    - Stability of camera operation when using OLYMPUS Capture has been improved.
    - Stability of image stabilizer operation when shooting video has been improved
    - Performance of C-AF when shooting still images has been improved.
    - Color reproduction of photographed images has been improved.
    - Stability of operation when shooting still images has been improved.
    - Corrected issue of autofocus (AF) function not operating correctly when using the "LEICA DG ELMARIT 200mm F2.8 / POWER O.I.S. (H-ES200)" interchangeable lens produced by Panasonic.
    Very nice if true. Hopefully we find out next week.
  5. #555
    Dec 2009
    4,289
    2 more days? We’ll see!
  6. #556
    Dec 2009
    4,289
    Panasonic officially unveils 50-200mm F2.8-4.0 ASPH
    Published Feb 26, 2018 | dpreview staff, quote:
    The Leica DG Vario-Elmarit 50-200mm F2.8-4 will be available in June for $1700.
    https://www.dpreview.com/news/685998...4010_132618830
  7. #557
    Dec 2009
    4,289
    This is a shot from last May with the ZUIKO DIGITAL ED 50-200mm 1:2.8-3.5 SWD. I bought this lens new last March when Olympus dumped their remaining stock of FT lenses at half price. Back then list price was $1,199.99, -$600.00 Discount, +$30.75 (US-NM (5.125%) Tax for a Grand Total of $630.74. Not bad, not bad at all.
    Canyon Towhee
    Olympus E-M1MarkII + ZUIKO DIGITAL ED 50-200mm 1:2.8-3.5 SWD @ ISO 200, FOCAL LENGTH 200.0 mm, APERTURE f/4, EXPOSURE TIME 0.00313s (1/320)
  8. #558
    Dec 2009
    4,289
    For our adventurous members! Use at your own risk! YMMV!!!
    https://www.dpreview.com/forums/thread/4259433
    brianric • Veteran Member • Posts: 7,410
    E-M1 Mk II Firmware Rev 2.0 installed.
    2 hours ago
    Just installed firmware 2.0. Some precautions should be noted.
    Recommend using Oly updater to backup settings and then restore after firmware update. Also recommend taking a picture with second card, do the firmware update as shown in below in a different sd card, then restore settings, then take one picture with second card only in camera only if you want to maintain your shot counter, otherwise your counter resets to 1.
    Go here to get firmware. Go here for instructions to install firmware.
    Initial observation. Pro Capture High works on PL 100-400 and P 35-100/2.8 Mk I along with my 4/3 14-35/2.0. Pro Capture low grayed out.. Haven't checked my other Panasonic lenses. I have no idea if Dual IS on PL 100-400. How do you check? When I turn off OIS on 12-100, S-IS1 disappears. Not so with PL 100-400. Will need info how to check Oly 8mm/1.8 fisheye. Small focus point can be selected. Will try and check out tomorrow features that I use. Sorry, not a birder.
  9. #559
    Dec 2009
    4,289
    https://lightsnowdev.com/Olympus/OMD/OMD-E-M1II-firmware-flash.html
    Rename the firmware
    Create a folder called "DCOLYMP" on your SD card.
    Rename the downloaded file to E1259999.BIN and put it inside this folder.
  10. #560
    Dec 2009
    4,289
    https://lightsnowdev.com/Olympus/how-to-flash.html
    How to flash a firmware
    The whole process will take a about 1-2 minutes.
    Make sure your camera is turned off at first. Now insert the SD Card with the firmware file.
    Start the camera while pushing the "OK" button.
    The screen will be black and the orange front LED will turn on.
    DO NOT TURN THE CAMERA OFF WHILE THE LED IS ON.
    Wait until it blinks rapidly.
    This means the process is finished. You can now restart the camera like you would do normaly.
    Attention afterwards:
    You may want to remove the "DCOLYMP" folder from your SD card, so you don't flash a new firmware by accident.
    End.
  11. #561
    Dec 2009
    4,289
    EM1.2 FW coming 28 Feb
    glassoholic • Senior Member • Posts: 2,114
    1 week ago
    https://www.dpreview.com/forums/thread/4256566
    https://www.dpreview.com/forums/post/60825832 quote:
    For those willing to install from SD card. Updater software does not show it yet
    http://dl01.olympus-imaging.com/OLYM..._0000_0000.BIN
  12. #562
    Knorp's Avatar
    5,267
    Well K-H, were you successfully adventurous ...
    Bart ...
  13. #563
    Knorp's Avatar
    5,267
    Anyway, forget that adventure as the update seems to be officially out now: Olympus offers major firmware update for OM-D E-M1 II, E-M5 II and Pen-F | dpreview
    Bart ...
  14. #564
    Dec 2009
    4,289
    Quote Originally Posted by Knorp View Post
    Well Bart, I was in the process of updating with the card when I noticed a new version of Olympus Viewer 3 was available. So I went the traditional route. My E-M1.2 now runs FW 2.0. And the small focus area is back.
  15. #565
    Knorp's Avatar
    5,267
    Aha great ! I know one happy camper here ... and No it's not me, but I'm happy for him !
    Bart ...
  16. #566
    Austria, close to Vienna
    4,581
    Updated the EM1.2 to FW 2.0 and 4/300 to FW 1.4.
    Works so far as expected - will see what the AF improvements really bring especially with AF-C and the 4/300.
    At least you have the feeling that you got a new camera/lens combo
    Life is an ever changing journey
    http://photography.tomsu.eu/
    https://www.flickr.com/photos/peter_...tography/sets/
  17. #567
    Dec 2009
    4,289
    So, I also updated my E-M5.2 to version 4.0.
    These are the changes:
    • New art filter [Bleach Bypass] has been added.
    • Focus Stacking has been added. ("M.ZUIKO DIGITAL ED 12-100mm F4.0 IS PRO" is also compatible.)
    • Corrected issue of autofocus (AF) function not operating correctly when using the "LEICA DG ELMARIT 200mm F2.8 / POWER O.I.S. (H-ES200)" interchangeable lens produced by Panasonic.
  18. #568
    Dec 2009
    4,289
    Quote Originally Posted by ptomsu View Post
    Thanks Peter. I followed your example and updated the 300/4 Pro lens to FW version 1.4. Are there any other lenses that need updating? TIA.
  19. #569
    Knorp's Avatar
    5,267
    Check the Olympus website for all new versions: Download Files: Software, Firmware, Drivers
    Bart ...
  20. #570
    Dec 2009
    4,289
    Thanks Bart. I can't find the link for the lenses.
    I found it
    Joint update service for OLYMPUS E-SYSTEM - OLYMPUS Digital Camera
    They only list new updates for 2 lenses.
  21. #571
    4,581
    All my other lenses did not require an update (12-40, 40-150, 1.8/17, 2.8/60 and 1.8/75).
    Best
    Peter
  22. #572
    Senior Member Elderly's Avatar
    Oct 2013
    UK
    424
    The VERY good news, and the confusing news .......
    The VERY good news is that just after downloading and installing the updates to my body and lens,
    we suffered a brief power cut, followed by a power surge which triggered the anti-surge shutting down my PC. I wonder what would have happened to my camera if the power cut and surge had happened during the procedure ?
    The confusing news is that single focus box appears to still be the same size as before
    Ian.
  23. #573
    Knorp's Avatar
    5,267
    Quote Originally Posted by Elderly View Post
    The small focus box is absolutely there, but you have to select it !
    Bart ...
  24. #574
    Oct 2013
    UK
    424
    Yes, I thought I'd done that - The [.]s I presumed. Or is that wrong? :Luddite smiley:
    Ian.
  25. #575
    Knorp's Avatar
    5,267
    You, your PC and your camera were toast ...
    Bart ...
  26. #576
    Knorp's Avatar
    5,267
    I think [.] is the home location of your focus box (most of the time the middle of the screen).
    Press Ok, select AF area, press Ok, turn front dial till you find the small focus box .. et violà !
    Bart ...
  27. #577
    Oct 2013
    UK
    424
    $1700 saved for the moment but bad for the Panasonic share price - Thank you Bart .
    Now to see IF the focus is constrained within the box and doesn't 'leak' to higher contrast areas close to and just outside of it
    Ian.
  28. #578
    Knorp's Avatar
    5,267
    Mmm, let me see: [.] is the normal focus box size (rectangular) and [.]s is the small focus box size [square].
    Bart ...
  29. #579
    Oct 2013
    UK
    424
    Hmmmmmmm I now have the small square focus box in green, which is what I want
    BUT, changing VIA THE MENU, I can't get the blue rectangular focus box if I wanted to -
    which I don't .
    My problem earlier was trying to select the size of the box via the menu (where I failed)
    but using your instruction to change the size via the SCP worked fine.
    I do find this camera less intuitive than my ex Nikon FM2
    Ian.
  30. #580
    Oct 2013
    UK
    424
    The manuals have now been updated too Now to learn to read !!!
    Download Manuals : OLYMPUS OM-D / PEN series
    Ian.
  31. #581
    Knorp's Avatar
    5,267
    which I don't .
    I've added random colour in the text to tell them apart ...
    Bart ...
  32. #582
    Knorp's Avatar
    5,267
    which I don't .
    The new manual that comes with firmware version 2.0 indeed doesn't mention the small focus box. I guess we're in for an imminent update ...
    Bart ...
  33. #583
    Oct 2013
    UK
    424
    Irrespective of the (your) colours, I cannot get back to the rectangle via the menu system,
    but that's not a problem as I can do it via the SCP.
    I wonder if any of this changes the 'Zoom frame' situation? ( I'm thinking to myself - no need to respond )
    Ian.
  34. #584
    Knorp's Avatar
    5,267
    Thinking out loud is a virtue of the "Elderly" ...
    Bart ...
  35. #585
    Dec 2009
    4,289
    That depends on how elderly someone is, no?
  36. #586
    Dec 2009
    4,289
    The power failure could have possibly bricked your unit.
    You would have gained a nice paper weight though!
    What would have bricked it for sure is if the power failure happened during the install phase.
    If it happened during the downloading phase (happened to me once) just try again later.
  37. #587
    Dec 2009
    4,289
    Well Bart, that's where the adventurous update version might succeed if you have your computer and camera attached to a UPS (Uninterruptible Power Supply).
  38. #588
    Oct 2013
    UK
    424
    In my case the first number is a 7 .......... if I've remembered correctly .
    Ian.
  39. #589
    Dec 2009
    4,289
    Well Ian, I will be joining your club pretty soon!
    This image of a Nuthatch was shot with E-M1.2 FW 2.0 and 300/4 Pro FW 1.4.
    Olympus E-M1MarkII + OLYMPUS M.300mm F4.0 @ ISO 800, FOCAL LENGTH 300.0 mm, APERTURE f/4, EXPOSURE TIME 0.0008s (1/1250)
    Seems to still work!
    Thanks 3 Member(s) thanked for this post
  40. #590
    Knorp's Avatar
    5,267
    Blimey - makes me feel a junior ...
    Bart ...
  41. #591
    Dec 2009
    4,289
    Bart, enjoy it while it lasts!
  42. #592
    Knorp's Avatar
    5,267
    Thanks K-H. I certainly will, but it's wearing off at an alarming pace ...
    Bart ...
  43. #593
    Dec 2009
    4,289
    Pro Cap Hi with E-M1.2 FW 2.0 and 300/2.8 SHG works.
    Pro Cap Lo is greyed out for this lens.
    Olympus E-M1MarkII + ZUIKO DIGITAL ED 300mm 1:2.8 @ ISO 500, FOCAL LENGTH 300.0 mm,APERTURE f/3.2, EXPOSURE TIME 0.0004s (1/2500)
  44. #594
    Dec 2009
    4,289
    My 4 Olympus FT lenses behave the same way.
    I have little tuna, z tuna, big tuna, and the 50-200/2.8-3.5 SWD.
    Pro Cap Hi is enabled, Pro Cap Lo is disabled.
    Also selecting Pro Cap Hi switches C-AF to S-AF.
    C-AF is disabled then.
  45. #595
    Dec 2009
    4,289
    A Junco Jump
    Olympus E-M1MarkII + ZUIKO DIGITAL ED 50-200mm 1:2.8-3.5 SWD @ ISO 800, FOCAL LENGTH 200.0 mm, APERTURE f/3.5, EXPOSURE TIME 0.0004s (1/2500)
  46. #596
    Dec 2009
    4,289
    I have posted 45 images here: E-M1.2 FW2.0 Pro Cap Hi - 45 images • 2 Juncos Aerial Combat - FM Forums
    The following image is taken out of the middle of the above sequence shot with Pro Capture.
    Olympus E-M1MarkII • FW 2.0 + zoom tuna ZUIKO DIGITAL ED 90-250mm 1:2.8 @ ISO 320, FOCAL LENGTH 250.0 mm, APERTURE f/3.2, EXPOSURE TIME 0.0004s (1/2500)
  47. #597
    Dec 2009
    4,289
    This is the first time I was using the highest frame rate (60 FPS) and retaining the last 35 images of Pro Cap Hi.
    Without these settings I could not have captured this entire amazing sequence.
    The birds finally drifted out of the frame.
    As they say, better lucky than smart.
    S-AF focused well on the Suet Feeder.
    But that takes a fair fraction of a second.
    Luckily the 2 Juncos stayed in that plane of focus.
    The FT zoom tuna 90-250/2.8 SHG is certainly a gem of a lens that I bought brand new when Olympus dumped their remaining FT lenses at half price when they announced that they had ceased production of FT lenses.
    Also I learned that a Junco can fly backwards, similarly to a Hummingbird. Amazing indeed IMHO.
    One more high resolution image.
  48. #598
    Dec 2009
    4,289
    Reaching Deep
    Olympus E-M1MarkII + ZUIKO DIGITAL ED 300mm 1:2.8 @ ISO 200, FOCAL LENGTH 300.0 mm, APERTURE f/3.5, EXPOSURE TIME 0.0004s (1/2500)
  49. #599
    Dec 2009
    4,289
    Evening Grosbeak
    Olympus E-M1MarkII + ZUIKO DIGITAL ED 300mm 1:2.8 @ ISO 320, FOCAL LENGTH 300.0 mm, APERTURE f/2.8, EXPOSURE TIME 0.0004s (1/2500)
  50. #600
    Dec 2009
    4,289
    House Finch • Titmouse
