Results 1 to 10 of 10
Thread: Difference between Canon FD and FL (BL) mount
    1,860
    I've been looking for an FD 35/2 and have found one at KEH with BL mount (breech). I never owned any of the older FD lenses and even looking at the photos of the two here http://canonfd.farah.cl/CanonFD_faql.html#mounts am not sure if my FD-m4/3rds adaptor will work. It appears so--there is no AF lever on the BL. Does anyone know if they are compatible?
    Never mind LOL--Stephen Gandy has info on his site stating that the adaptor will work with the FL lenses.
    Diane
    Nov 2008
    3,848
    Re: Difference between Canon FD and FL (BL) mount
    Yep, it'll work, it just is a different action to attach the breech lens.
    Ranger 9
    And it sticks in the musty corners of my mind that if FD(n) (pseudo-bayonet), FD (breech-lock) and FL (breech-lock) lenses work, R lenses should also work... I seem to recall reading that the mount flange and back-focus distance are identical, the only differences being the actuator levers and signal pins. Any Canonistas know if this is true? Or am I just having false-memory syndrome again?
    1,860
    Thanks, and that's interesting about the R lenses if true (I need to do a bit more research on that).
    Diane
    Deceased, but remembered fondly here... johnastovall's Avatar
    Dublin, Texas, U.S.A.
    1,549
    112
    A very good resource for all questions regarding Canon bodies and lenses it the Canon Museum.
    The Lens section is a outstanding for research on the optics of the different lenses and mount systems.
    "The market wants a Leica to be a Leica: the inheritor of tradition, the subject of lore, and indisputably a mark of status to own."
    Mike Johnston
    Ranger 9
    Quote Originally Posted by Diane B View Post
    Diane
    This from the Canon Compendium [Hove Books, 1994], by Bob Shell (and no Bob Shell jokes!):
    "It is important to understand the differences in these mounts. Contrary to what you may have heard, any Canonflex, Canomatic or Type R lens will fit any Canon camera with FL or FD mount, and likewise any FL-mount lens will fit on any Canonflex. They will focus to infinity. However, since the diaphragm linkages are totally different, the diaphragms will not operate automatically...
    ..."Except for the addition of the aperture follower lug, the FD mount is identical to the FL mount, and all FD-mount lenses can be used on older FL-mount and Canonflex cameras...
    ..."When the AE-1 was introduced in 1976, Canon introduced a new variation on the FD mount, called informally "FD-N". This mount was odd in that it worked like the existing breach-lock [sic] mount and was fully interchangeable with the older lenses, but was mounted and dismounted on the camera by turning the whole lens."
    Don't know how this info applies to mounting them on a Micro Four Thirds adapter, but if this info is correct, the flanges and back focus at least should be compatible.
    Mar 2008
    Santa Monica CA
    83
    I just discovered that I have a Canon FL 35mm f2.5.
    Is this a good lens? Sharp? Contrast?
    Worth getting an adapter for it?
    Antara
    1,860
    Quote Originally Posted by antara View Post
    Antara
    Antara, I don't know if this will give you any information you need, but here's a link to the FL lenses
    http://www.mir.com.my/rb/photography...nses/index.htm
    I just bought an FD 35 f/2.8 (couldn't find an f/2 and its also a much larger than the f/2.8 and I'm trying to remember one of the reasons I bought the G1--size/weight). I'll be curious about the FL 35 f/2.5
    Diane
    Mar 2008
    Santa Monica CA
    83
    Diane, a quote from that link. Not sure exactly what that means. Any thoughts?
    "FL 35mm F 2.5
    A retrofocus type wide-angle lens with a large aperture, passing a large quantity of marginal light because of the two large elements in the front group. This lens has very flexible characteristics in that soft delineation. And it is possible at maximum aperture while very sharp pictures are available when the aperture is closed down."
    Thanks for the lead,
    Antara
    1,860
    I read the same thing LOL. I really was not quite sure what it meant--think I understand the first sentence--not sure of the second one though LOL.
    Here is a link to The Online PHotographer' who talks about retrofocus lens if you scroll down a bit.
    http://theonlinephotographer.blogspo...rime-lens.html
    Diane
