Results 1 to 7 of 7
Thread: Olympus magnification and peaking for manual focus - NEED HELP
    420
    I just bought a Pen-F for vacations and have been having fun setting it up, but I'm having a problem with manual focus.
    I only bought 2 lenses. The 12-40 Pro and the 17/1.8. Both lenses have the manual ring on them to switch between AF and MF.
    The 12-40 reacts exactly as I would expect for how the camera is set-up. I move the lens ring to MF and start to focus, then the VF magnifies and uses peaking. Both features are turned on in the menu.
    The 17/1.8 does neither of those functions when I move the lens ring to MF and start to focus. It does focus, but with no magnification and no peaking. Both features are turned on in the menu. I press the magnification button above the main rear dial and it does magnify, but no peaking.
    Am I missing something, or the lens defective?
    Thanks for any help.
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,957
    Re: Olympus magnification and peaking for manual focus - NEED HELP
    Hi There Ray
    I'm not sure about this one, as I don't use magnification or focus peaking much - it seems unlikely that there's a fault with the lens, but what happens if you turn the camera on to manual focus (rather than using the push-pull ring)?
    Just this guy you know
    849
    Quote Originally Posted by harmsr View Post
    Mine behaves exactly the same, with different lenses and MF turned on via menu/assigned button. I hope it's user error.
    420
    It works if I assign MF via menu or dedicate a button to it. Just seems weird. The 17 switches to MF with the lens ring switch, but does not magnify or focus peak unless assigned to MF via menu or button. The 12-40 does everything it should just by moving the lens ring switch.
    420
    Just talked to Olympus support and seemed to surprise them with the issue.
    Their temporary fix is what I already did, of assigning a button to MF if I want to magnify and peak with the 17/1.8.
    Evidently the 17 works normal as the 12-40 on other cameras vs. the Pen F.
    The firmware for the Pen F will need to be updated to fix the issue with the 17/1.8.
    Member zensu's Avatar
    Feb 2014
    Montgomery, AL, USA
    21
    It's good to hear that Olympus acknowledges a problem and suggest (I hope) an up coming correction.
    Bobby
    Bobby
    "Reality leaves a lot to the imagination." John Lennon
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    8,526
    Yes, a new model fw glitch. I'm sure they'll correct it.
