Results 1 to 2 of 2
Thread: e-m5 mk2. How often do folk use Manual and Lever 2?
    Jan 2010
    392
    I shoot quite a lot of theatre productions. I use Manual all the time as I find Auto Exposure gets too confused by the lights on the stage.
    Up to now I have been setting what I felt was an ASA that would cover me for the dimmest lit scenes - and adjusting the speed/aperture as the lighting changed.
    It has just occured to me that I am probably better equipped if I chose my speed and aperture and worked with the Lever in position 2 where I can alter the exposure by raising or lowering the ASA.
    The default sets the front dial for the changes. (That seems OK and I am not sure that reversing it so the back dial handles ASA is any more logical.)
    I have never read about anyone working this way.
    I wonder why.
    All comments from the gurus are, as always, warmly welcomed.
    Tony
    London UK
    Pratamnak
    10,880
    2539
    Re: e-m5 mk2. How often do folk use Manual and Lever 2?
    I don't shoot Olympus and I mostly use aperture priority, so what I say may not be relevant to how you shoot, but here's how I mostly use my Panasonic cameras:
    I shoot in Aperture Priority and adjust the aperture as suits the situation and don't worry much about exposure time unless I shoot moving subjects. ASA/ISO is set to Auto, but I frequently adjust the maximum ISO level by pushing the the relevant buttom and turning the front command wheel.
    I do it this way because most of the time, it's more important to me to have control over noise in the photo than exposure time, again unless I shoot moving subjects. In that case, I change to Shutter Priority and follow the same procedure with regards to maximum ISO.
