Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 51 to 100 of 193
Thread: Panasonic G1 45-200mm
  1. #51
    Wisconsin
    3,580
    118
    Re: Panasonic G1 45-200mm
    Quote Originally Posted by Scott G View Post
    In the zone
    Both taken at 400mm equivalent @ f5.6
    Scott, This is an amazing image. You did a great job on this one.
    We really got a bargain with this lens, didn't we?
  2. #52
    Jan 2009
    Baltimore, Maryland USA
    466
    Hi Cindy,
    Thanks, it is an amazing lens. I need to play with it more often, along with the G1 in general. I like them both more and more...
  3. #53
    pnd1
    Thanks, Terry, for the tutorial on uploading and positioning photographs to this forum. I played around with it, and eventually got that second box to appear. Once that happened, I was able to make it work, and I have successfully posted additional photographs in post #11 of the "Black and White pics" thread at http://forum.getdpi.com/forum/showthread.php?t=7517 I was even able to position each photo below the supporting commentary. Thanks for your help.
    Phil
  4. #54
    Mar 2009
    257
  5. #55
    1,860
    Quote Originally Posted by pnd1 View Post
    Phil
    Sorry, Phil, that I hadn't even considered embedding by loading the photos here. I have never done that--link from my web gallery. Glad Terry got it sorted out for you. I'll check out your b & ws.
    Diane
  6. #56
    pnd1
    Thanks, Diane, for your help. With some experimentation, I was able to figure it out -- I am used to pbase, which for me, anyway, is a bit easier for a newcomer to grasp. I am indebted to you and Terry for your kindness in helping me work things out. Things should go a bit easier from now on.
    Phil
  7. #57
    1,860
    Just to revive this thread a bit. Two from the 45-200--processed as monos.
    Bluebird f/5.6 1/200s ISO 160 200mm
    Rainy Day Visitor f/5.6 1/250s ISO 100 200mm
    Diane
  8. #58
    Michiel Schierbeek's Avatar
    Mar 2009
    Amsterdam/Normandy
    4,055
    762
    1. Union Square, New York City. In this case, I am using the long focal length to compress distance and juxtapose subjects that are city blocks apart.
    Phil, this photo convinced me to buy this lens. Very interesting the way you explain your view on things, on looking. I was waiting for this thread about this lens too.
    We are going to Canada soon and I want to travel light. Just the kitlens, the 45-200, the Oly 9-18 and may be 35mm Olympus macro for the small things.
    I also like to work with a lot of DOF to sort o flatten the distances in between.
    Lik this one for example.
    And Diana, I really like your rainy visitor.
  9. #59
    May 2009
    Essex UK
    71
    Hi I noticed earlier in this thread that someone mentioned that they used there G1 and 45/200 at 800 in EZ mode, can someone please explain what this is, I am guessing it is a digital zoom feature, but stand to be corrected
    Many thanks
    Phil
  10. #60
    Member sangio's Avatar
    Feb 2009
    London, Ontario, Canada
    119
    24
    Quote Originally Posted by deckitout View Post
    Many thanks
    Phil
    Hi Phil:
    According to the manual, pg 48, this is an in-camera crop. This mode uses 3.1 mp from the center of the image circle to produce more of a telephoto effect.
    regards
    Santo
  11. #61
    Feb 2009
    119
    24
    I just got back from a two week trip to Italy where I used both the 14-45 and 45-200 on my G1. The 14-45 performed great, the 45-200 was, well, OK I guess. I'm seeing some fairly noticeable cormer shading at most focal lengths, and it's quite severe past 150 mm. I know it can be corrected in post, but I'm wondering if this is normal, or if I might have a bad copy?
    I've attached some examples. All were taken at 200 mm and F6.3. No croping, just resized and some USM for posting. The first is uncorrect; the second has had some vignetting correction applied in Silkypix.
    regards
    Santo
  12. #62
    Senior Member f6cvalkyrie's Avatar
    Feb 2009
    Belgium
    1,643
    29
    during my traditional sunday morning walk, I concentrated on the 45-200mm, a lens I do not use enough.
    Here's two close-up shots of an insect, thanks to the 200mm focal length, I could keep a sufficient distance not to disturb the animal.
    Both @ 200mm f5.6 iso100
    C U
    Rafael
    E-M1/GH2/G1 Full Spectrum & lots of lenses
    http://www.flickr.com/photos/f6cvalk...th/9226689839/
  13. #63
    Mar 2009
    257
  14. #64
    Feb 2009
    Belgium
    1,643
    29
    here's a few I shot yesterday with this lens :
    @ 200mm
    @ 67mm
    C U,
    Rafael
  15. #65
    Feb 2009
    Belgium
    1,643
    29
    Yesterday evening, I noticed that our clematis are opening nicely now.
    The background was a mess, so I cleaned it up in PSP X2
    G1 with 45-200mm @ 45mm iso 100 f4.0
    C U,
    Rafael
  16. #66
    Jan 2009
    USA
    1,763
    45
    Smile Re: Panasonic G1 45-200mm
    Quote Originally Posted by f6cvalkyrie View Post
    C U,
    Rafael
    Hello Rafael,
    This image is stunning! The color is fantastic. Best regards, Leica 77
  17. #67
    Feb 2009
    Belgium
    1,643
    29
    I continue to appreciate the 45-200mm as a close-up lens that allows you to keep distance to the subject, and to have shallow DOF :
    F5.6 iso100
    f5.6 iso400
    C U,
    Rafael
  18. #68
    Senior Member ecsh's Avatar
    Jun 2009
    Tax State
    549
    A couple i took today. This lens is really softer than the 14-45, and seems more prone to unfocus through movement more than anything else.
  19. #69
    Reed
    Hi all,
    I am the potential owner of a GH1. Moving to a lighter camera from a much heavier Nikon. With my Nikon telephoto lenses, I had very good luck with close-ups using the Cannon 500D two element close-up lens. Has anyone tried such a lens on the 45-200mm lens?
    Reed
  20. #70
    Terry's Avatar
    New York City
    6,955
    1145
    Quote Originally Posted by Reed View Post
    Hi all,
    Reed
    I've tried the 250D which is a bit more magnification. Works fine. It has just been a wee bit windy where I live to get good shots! The lens is 52mm which may be the same as your Canon. I have one close up that is 52 and the other is larger.
  21. #71
    1,860
    Quote Originally Posted by ecsh View Post
    Remember the FL. At 200 it would be like handholding a 400mm (FOV/35mm) . I have trouble with my Canon 70-200 f/4 LOL. I'm actually pretty amazed how well the IS works for the FL. I do think its not as sharp at the long end but its still a really good value and with good technique and good processing, very good photos result.
  22. #72
    Reed
    Actually I have a 72mm Canon 500D for the Nikon 18-200mm lens, and a leftover 77mm 500D from the 300mm f/4 tele I just sold. I would need to get a 52mm for the 45-200 and/or a 62mm one for the 14-140mm lens. Either would be cheaper than buying a macro lens. What are your thoughts on how the Canon diopter lens would work on the 14-140?
    Reed
  23. #73
    FredB
    I have only a few with the 45-200mm I noticed it is still hard to get close enough to them feisty birds lol
  24. #74
    FredB
    A few more from today
  25. #75
    tripper
    My photo's in the 14-45mm kit lens thread were well received (many thanks for that) so let's not forget the 45-200mm which is pretty capable. I think it is easy to forget that you may be shooting with an effective focal length of 400mm hand held !
    1. Sedge warbler (Acrocephalus schoenobaenus)
    Listen to this strident little bird sing here http://www.rspb.org.uk/wildlife/bird...bler/index.asp
    200mm f/6.3 1/400s iso200 hand held.
    2. Sanderling
    151mm f/9 1/400s iso200
    3. Black headed gull
    200mm f/6.3 1/250 iso200
    tripper
  26. #76
    Feb 2009
    Belgium
    1,643
    29
    Lovely shots, tripper !!
    Here's some I shot tonight :
    171mm iso160 f5.4
    124mm iso100 f5.0
    C U,
    Rafael
  27. #77
    1,860
    Tripper, I really enjoyed your boat photos. Just lovely. I listened to the warbler (I love warblers)--no wonder he has his mouth open LOL. Do you live near the coast?? We so rarely would find shots like you have posted on our eastern coast--so much is 'condo-ized' or just big power boats. You really have to search for anything similar so I'm really enjoying them.
    Raf--as usual--lovely, esp. the second.
    Diane
  28. #78
    tripper
    Red face Re: Panasonic G1 45-200mm
    Quote Originally Posted by Diane B View Post
    Diane
    My thanks to Raf and Diane for your kind words.
    Diane, no I live in the English Midlands about as far from the coast as you can get which ever direction you travel ! Hence my fascination with photographing boats, I rarely see them. Recent pictures were all taken when we were taking a break and staying on the coast of Norfolk. I got lucky with the warbler, I saw it a couple of times in the same place while walking my dogs thru the reed beds near the coast so guessing it had a nearby nest I returned with my G1 and waited....... not for too long. Like the Robin it is a 'brave' little bird and allowed me to get very close. Like yourself I rarely shoot birds. . . too difficult so this was a bonus.
    tripper
  29. #79
    Feb 2009
    Belgium
    1,643
    29
    thank you, Diane !
    Here's a Zen lady in our forest :
    184mm iso400 1/160sec
    C U,
    Rafael
  30. #80
    1,860
    Ah, Tai Chi, Raf.
    I love opening up this forum in the morning and seeing the photos that others in other parts of the world have shot recently.
    Diane
  31. #81
    Senior Member Joan's Avatar
    Apr 2008
    477
    8
    More beauties, Tripper. Just love them, especially the little warbler!
    Raf, enjoy all of your flowers, really lovely and like the pose of your Zen lady! Nice shot!
    Tripper, a distant cousin of your black headed gull:
    And another shirt tail relative:
    Regards,
    Joan
  32. #82
    Senior Member apicius9's Avatar
    Feb 2009
    Honolulu, Hawaii
    329
    My buddy Jacob having fun in the pool.
    Stefan
  33. #83
    Feb 2009
    Belgium
    1,643
    29
    Joan & Apicius,
    you both share some very nice pics, thanks for that !
    Rafael
  34. #84
    Feb 2009
    Belgium
    1,643
    29
    Here's a few butterflies I shot yesterday :
    45-200 mm @ 200m and still some cropping
    C U
    Rafael
  35. #85
    Feb 2009
    Belgium
    1,643
    29
    Let me show you some more flowers from the Botanical Garden in Leuven :
    (iso100)
    (iso320)
    (iso100)
    CU,
    Rafael
  36. #86
    Mar 2009
    Amsterdam/Normandy
    4,055
    762
    Saw some really nice pics in this tread with this lens. Love the first birdphotograph of Tripper. And it's very good for flowers too, Raf!
    I did hestitate a lot about this lens, but I finally bought it in Toronto.
    I needed a stabilised longer reach. I did make some decent pictures of the wedding of my niece on Wolf island, which I will not show without there permission.
    The first two are from Wolf island and the other two from today.
    Thanks for looking, Michiel
  37. #87
    Senior Member RichA's Avatar
    Jul 2009
    544
    Quote Originally Posted by cap'n bill View Post
    There seems little comment on this lens and I haven't seen many examples of it. I didn't get one when I bought the camera and am wondering whether to get one now. Advice and pictures please.
    This site didn't think much of it.
    http://www.photozone.de/olympus--fou...00_456?start=2
  38. #88
    Mar 2009
    Amsterdam/Normandy
    4,055
    762
    Quote Originally Posted by RichA View Post
    That is why I hestitated but some people can make good photographs with it.
    Till 150mm it is quiet good. It is not as sparkling as the kitlens but you have more stabilised reach and that is important to me.
    Michiel
  39. #89
    Jan 2009
    USA
    1,763
    45
    [QUOTE=Michiel Schierbeek;121095]Saw some really nice pics in this tread with this lens. Love the first birdphotograph of Tripper. And it's very good for flowers too, Raf!
    Hello Michiel,
    I really like this digital image of yours! Nice pattern and composition. Best regards, Leica 77
  40. #90
    Jan 2009
    USA
    1,763
    45
    (iso100)
    CU,
    Rafael
    Hello Rafael,
    This is a fantastic image. Nice details! All the best, Leica 77
  41. #91
    Senior Member petermcwerner's Avatar
    Jan 2009
    Geneva, Switzerland
    511
    Let me show you some more flowers from the Botanical Garden in Leuven:
    Beautiful images Rafael. I just bought one and have not used it much. It would help my learning curve if you could please show the tech data.
    Were they handheld or on tripod, illumination, focal length, diaphragm, shutter speed, ISO, Raw or Jpeg?, AF and mode or MF, stabilization mode
    Thanks in advance,
    Peter
    Peter Werner
    Leica M8, R9+DMR & Digilux 2; Nikon D700; Panasonic FX01, FX150 & G1; Samsung TL350 (WB 2000)
  42. #92
    Irwell
  43. #93
    Feb 2009
    Belgium
    1,643
    29
    Quote Originally Posted by petermcwerner View Post
    Thanks in advance,
    Peter
    Hallo Peter,
    no secret in there
    #1 : 200mm iso100 1/800 f5.6 handheld (outside shot)
    #2 : 136mm iso320 1/200 f5.1 on tripod (shot inside a greenhouse, quite dark there)
    #3 : 78mm iso100 1/2000 f6.3 handheld (outside, backlight)
    All shot in RAW, converted and worked up with Silkypix. Manual focus. OIS on.
    My personal guideline for shooting with this lens handheld, is to use a shutter speed faster than 1/x where x= focal length. Otherwise, you are at risk for blurry images !
    C U
    Rafael
  44. #94
    Feb 2009
    Belgium
    1,643
    29
    Final approach, preparing to land
    Landed !
    Both @ 136mm iso100 1/800 f5.6
    CU,
    Rafael
  45. #95
    Jul 2009
    544
    Quote Originally Posted by Michiel Schierbeek View Post
    Michiel
    No, the images posted here look good which was kind of a surprise for me. But a welcome surprise!
  46. #96
    Jan 2008
    Toronto, Canada
    3,026
    1117
    This was taken on my G1 and the lens is much easier handled on the G1 than my E-P1
    I also like the controls on the G1 better than the EP-1, but having said that, you have to have both cameras if you are a micro 4/3 fan
    G1, F8, handleld 1/125s, ISO 200
    Keith
  47. #97
    Feb 2009
    Belgium
    1,643
    29
    Especially for you, Peter
    (144mm iso100 1/400)
    And for all of us
    (120mm iso100 1/640)
    I have two visitors !
    (200mm iso125 1/250)
    C U,
    Rafael
  48. #98
    46
    Well, I started this thread and it seems to run and run. I eventually sold my Olympus ZD 50-200mm f2.8 and bought the Panasonic 45-200mm It's no way as good as the ZD but it autofocuses quickly and is half the size and weight. It also cost less than half the price I got fot the 50-200mm. I'm reasonably happy with the results from it. Here is a typical shot at 200mm.
    The big difference is that with the 50-200mm I could happily operate at full aperture and blur the background.
  49. #99
    Wisconsin
    3,580
    118
    The Village of Eden, Wisconsin held their annual Fireman's parade today. I used the G1 with the 45-200mm. It did a better job than my D700 did last year!
  50. #100
    Terry's Avatar
    New York City
    6,955
    1145
    Haha Cindy - sounds like you are getting closer to paring back your gear
