Results 1 to 5 of 5
Thread: G1 - focus mode dial
    phil
    Question G1 - focus mode dial
    sorry if this has been discussed elsewhere ( I have searched) - on the G1 does it make any difference if the focus mode dial is set to manual focus when using an M lens? Should it be moved from normal AFS or AFC? - thanks
    Jan 2008
    North Vancouver, BC
    1,168
    Re: G1 - focus mode dial
    Set to MF to enable the focus assist mode of the LCD/EVF.
    Wisconsin
    3,580
    118
    Phil,
    You will need to set "Shoot W/O lens" to ON in the Custom Menu if you have not done so.
    phil
    Thumbs up Re: G1 - focus mode dial
    thanks for your comments and swift response - what I find is that the focus assist works just the same whether or not I set the dial to manual focus! I have set "shoot without lens". - regards, Phil
    Senior Member Per Ofverbeck's Avatar
    Feb 2008
    503
    5
    Quote Originally Posted by phil View Post
    Yes, I have the same experience: the position of that dial doesn´t matter when shooting with other brand lenses on an adapter, so I just leave it where it is.
