Results 1 to 9 of 9
Thread: 8mm f/2.8 Stilar in C-mount
    Senior Member petermcwerner's Avatar
    Jan 2009
    Geneva, Switzerland
    511
    On the German 4/3 Forum I found the following link. The technical data sheet mentions an image circle diameter of 21.43mm; it could work on the G1 and cover the whole sensor.
    http://www.docteroptics.com/en/Optic...lar_2,8_8.html
    Does someone know more about this lens?
    Cheers
    Peter
    Peter Werner
    Leica M8, R9+DMR & Digilux 2; Nikon D700; Panasonic FX01, FX150 & G1; Samsung TL350 (WB 2000)
    milapse
    Re: 8mm f/2.8 Stilar in C-mount
    Ahh nice find! Looks interesting but I'm going to guess it won't fit the adapters without some modification (I scaled the diagram properly and measured the flange):
    Any idea how much it costs and where it can be found??
    Jan 2009
    Geneva, Switzerland
    511
    Quote Originally Posted by milapse View Post
    From what is said on the web site, this lens does not seem to be in production or for sale to the public yet.
    Interesting facts about the company: it is the maker of the TEVIDON brand lenses and is based in Wetzlar. Among the shareholders: Rodenstock, Bosch and Hella. In 1991 it acquired part of Carl Zeiss Jena
    Peter Werner
    Nov 2008
    3,848
    Very interesting. A superwide that could actually cover the sensor. But it does appear surgery would be necessary, maybe a c-mount adapter with the outside ring removed would work...
    Mar 2009
    90
    Really worth a try, if it is not as much as the Schneider Xenoplan, 1.3" sensor coverage for 24/28/50mm. Almost the same value of Leica.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,601
    21
    Wouldn't the rear elements hit the shutter?
    That would make the whole trial that much more expensive!
    Mar 2009
    90
    Just got an official reply from Doctor optics. The 8mm lens costs 1,900 Euro.
    Other Tevidon lenses cost about 350 Euro, from 10 - 35mm. But they might not be able to cover 1.3" sensor.
    Just go dreaming for it, ar ha...
    Mar 2009
    Miami
    164
    I am afraid the surgery might not work on this lens.
    The elements of wide angle lens are at the very back of the lens. There might not be enough room to operate.
    Ranger 9
    This lens would be more appealing if it weren't only one stop faster than the more versatile Panasonic 7-14 f/4... not that either of them is exactly easy to find in the real world!
