Godfrey
You just don't want to let this end, Jono. I will respond this one more time, then I'm unsubscribing from this message thread as I don't have the time to waste in nitpicking this topic to bits, nor do I feel it is of service to the original poster.
Actually, the fact that Adobe tools and Open Source dcraw-based tools support native .RW2 format processing already, one with and one without the inclusion of the lens correction metadata, means that .RW2 format RAW files will be exactly as processable into the future as every other RAW format out there.
When the update to the Digital NeGative Specification format to incorporate this new form of lens correction metadata has been completed, there will be no problem writing the DNG files' sensor data in mosaic form as well as linear form so that all applications honoring the DNG specification can do the appropriate processing job to the manufacturers' intent. As I stated in my original post.
One of the reasons I don't use Capture One or Aperture is incomplete support of a specification they list as supported but isn't, really.
- demosaic into channel representation, which assigns chroma values in photosite quantization space.
- gamma correction
- interpolation of photosite values to channel valued RGB pixels in 32bit, 16bit, or 8bit space
- export to target file as RGB (TIFF, JPEG, etc)
The linear representation DNG file essentially does the first of these steps, leaving all the RAW metadata inserted by the camera intact and without doing any of the gamma interpolation and other image processing adjustments.
Could you write the data as a TIFF file in this form and do the processing manually? I'm sure you could ... DNG is, after, simply a well-defined specialization of the very general TIFF file format structure (which, btw, Adobe also owns and maintains). But you'd give up the standardization of the RAW file format that the DNG specification was intended to supply.
The intent of the linear representation form is to allow generalized processing of RAW data by applications that might not yet have been updated with the mosaic decode specifics for new hardware. Not supporting it essentially reduces the scope and value of an application's DNG support.
I am not willing to waste my time researching who or what is doing what out there ... there are over 40 different applications that can consume and work with DNG files at the present time, and there are at least 10 cameras and other devices that can generate DNG files.
I believe VueScan creates linear DNG RAW files from a wide range of image scanners. I don't know of others off the top of my head.
I use Lightroom because I find it works best for my uses, and because my testing and evaluation indicates no advantage to using other software.
I test about six or seven different RAW converters every year as versions are released. I have yet to find any substantive advantage to changing my workflow on the basis of quality of output from any of them. I have seen none of the alleged "poor demosaicing" problems that you seem so bent out of shape by, and in general this insistent, picayune decomposition of every statement reflects your bias and preferences as much as my opinions reflect mine. It's a waste of time and energy to argue about it.
Yes: please just agree to disagree and stop trying to bicker with me. If you like some other software, fine. If you don't like the G1, fine. Use what you like, make nice photographs.
I'm done with this discussion. You're making this forum into DPR all over again.
ALL native RAW file formats have the same future support issue. There is nothing different about Panasonic as opposed to any others, including Nikon and Canon. Nikon, in particular, has inserted their own, private, encrypted metadata into .NEF files and only under coercion from their userbase released *some* of it to Adobe to enable Adobe to do a better job of processing NEF files.I wasn't meaning to imply that Panasonic were limiting support to
their own converters at all - simply that this could be the
upshot of the move. Producing 'off beat' RAW files for niche
cameras inevitably ends up with reduced support in the industry.
Even if the intention of the manufacturer is as pure as the
driven snow.
How many raw converters will deal with these RW2 files in 5
years?
The DNG specification is what it is. Either you implement it fully or incompletely. In my opinion, an incomplete implementation means that you don't actually support it. Period.Perhaps all the other raw conversion software you have will support linear DNG, but it certainly isn't the case that all other raw software does.
The RAW conversion process, in first order approximation, requires the steps:Can you tell me, in practical terms, what the difference between a linear .DNG file and a .TIFF file.? It seems to me that if the demosaicing is done, then all that is left to be dealt with is exposure and colour, and that can be done just as well in an ordinary .TIFF file.?
- gamma correction
The DNG Spec includes the linearly represented DNG format. Not supporting it means you are not supporting the full DNG spec. Period. Aperture and Capture One seems to implemented with the notion that supporting a subset of the DNG spec is sufficient for their purposes. You seem to agree with that.I think that this remark is disengenuous - If I was in charge of development of raw conversion software I'd be very suspicious of providing support for a clumsy backwater of the standard which required that you rely on someone else's demosaicing routine (Adobe's in this instance) - and to be criticised if that routine wasn't good enough.
You can write the code to do it by signing up for the DNG use and distribution license and writing code to the specification.Just as a matter of interest, is there any other way of getting a linear .dng file except using Adobe's dng converter?
And I won't be buying any of their software either. They don't fully support the DNG specification.As I pointed out above, Apple certainly aren't the only company which isn't providing support.
My comments have NOTHING to do with "liking" Lightroom.I understand that you like Lightroom...
