Results 1 to 12 of 12
Thread: Small 20mm equivalent for m4/3?
    Senior Member Rawfa's Avatar
    Nov 2008
    Rio de Janeiro
    2,393
    Is there a lens out there with a 20mm equivalence (should be a 10mm micro four thirds) that is small, portable and that can be used on the micro 4/3 system via adapter? I'd really like to have a 20mm fov with the E-P1 with a small compact lens.
    Member slosync's Avatar
    Jan 2009
    Florida, USA.
    97
    Re: Small 20mm equivalent for m4/3?
    Quote Originally Posted by Rawfa View Post
    Hi Rafa,
    Check out this link....
    http://forum.getdpi.com/forum/showthread.php?t=6170
    And check out this lens compatibility chart....
    http://spreadsheets.google.com/pub?k...QQ-HJwvNDobeEw
    Don
    Nov 2008
    Rio de Janeiro
    2,393
    Thanks, Don. I've checked out the Cinegon 10mm/F1.8 and even though the performance looks great, it's a massive lens. It doesn't necessarily have to be 10mm. It can be less than that.
    I'm going to take a look the compatibility chart you've posted.
    Fort Collins, Colorado
    2,077
    Rafa
    Don't overlook the 20mm lens from Cosina Voightlander made for the Nikon F mount. I think it does a terrific job on my D3 and D3X but I don't have a micro 4/3 for testing.
    Woody
    May 2009
    Southport, Australia
    1,429
    Quote Originally Posted by woodyspedden View Post
    Rafa
    Woody
    which is of course effectively a 40mm lens on a 4/3rds sensor ... and since the poster was asking about equivalent focal lengths I guess he was meaning something that will make an image as wide as that looks.
    to rawfa I'm using a C-mount lens too, but its quite cheap. its 12mm but sadly does not have full frame coverage. This is it beside my Olympus 21mm
    and here's a sample image
    Senior Member back alley's Avatar
    Feb 2008
    the frozen north
    428
    3
    has anyone used the cv 12 on the g1?
    Ranger 9
    This isn't what the poster wanted to hear, most likely... but if you need full frame coverage and good image quality, the easiest thing might just be to get the Pana 7-14.
    Not exactly small, and not exactly cheap. Sounds like the old joke about offset printing: "Good... fast... cheap... pick any two."
    Nov 2008
    Rio de Janeiro
    2,393
    Thanks, guys. I might start checking some C-Mount lenses.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    Quote Originally Posted by Ranger 9 View Post
    Yes. Unless you go to the trouble of making your own "small, fast, wide" prime,
    there isn't anything in c-mount that I am aware of.
    FWIW, I had a 9.8/1.8 Kinoptik Tegea lens (~1.5Kgs, >80mm dia front element).
    Jan 2009
    College Place, WA.
    790
    I doubt you'll find a 10mm c mount that will cover the whole sensor, or will be free of the smearing that so often plagues these lenses.
    Look to 35mm format arris for your super wide needs, or as someone said, the Pana 7-14.
    Or consider the Nikon 10.5/2.8 fisheye. It will cover the sensor.
    valtof
    Quote Originally Posted by back alley View Post
    The CV12 does quit a good job on the G1 even if it's not as good as the Lumix [email protected]
    And after all, a lens equivalent to f:5.6/24mm doesn't sound really exciting !
    Nothing relevant to show you, all is taken at f:5.6, focus set to infinity, and processed in LR.
    I'm really waiting for the Lumix 7-14 to be available in France...
    Cheers
    milapse
    Massive? it fits into a very small space! Flare is it's biggest weakness imho...
