Results 1 to 17 of 17
Thread: Best M-adapter and why?
    415
    77
    Please advise to which Leica M adapter to get to use with E-P1 or GH1 and why. I have a 35 Cron and a 50 Lux. Also, which VF would work for both the 50 and the 35? Thanks to all.
    415
    77
    Re: Best M-adapter and why?
    Thanks for all the advise.
    Apr 2008
    22
    I think the Rayqual one is the best. Reason being is it didn't have any focusing issues.
    Senior Member RonSmith's Avatar
    May 2009
    Michigan USA
    432
    I got the Voigtlander adapter from Camera Quest. It works fine with all my M lenses.
    Ron Smith
    Flickr
    Nov 2008
    3,848
    All the current adapters are of good quality, the Rayqual and Voigtlander stand out as the best quality machining.
    415
    77
    Thank you. i have used Stephen at CamerQuest before so I think I will try the Voigtlander as well as a 75mm VF for my 35 & 50.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,601
    21
    RayQual without any question.
    Oct 2008
    254
    Panasonic will be selling M and R leica adapters soon. I'll wait for them if I were you.
    May 2009
    Michigan USA
    432
    Quote Originally Posted by cdnguyen View Post
    Although I haven't seen any information on when those will become available, Panasonic's adapters look very similar to the Voigtlander. Might, in fact, be the same thing.
    Ron Smith
    Flickr
    Apr 2009
    Vancouver, BC
    221
    The Panasonic adapters are available now (at least in Hong Kong) and I've just ordered some. On the advice of someone I trust and who has used the various ones, including the Voigtlander and (pre-Voiglander) Cameraquest ones, those are apparently the best. No binding, no uneveness of any sort or any other issues.
    Henning
    Senior Member JMaher's Avatar
    Sarasota
    942
    16
    How do the Panasonic adapter compare in price? Are they more or less than the 4/3 to m4/3 adapter?
    Jim
    Sarasota
    942
    16
    What about the one from:
    http://stores.shop.ebay.com/RJ-camer...__W0QQ_armrsZ1
    Less than $100.
    Jim
    daggerlee
    Has anybody tried Hawkpeng's L(M) adapter? From what I've read on here, it seems RJ's focuses slightly past infinity, while the Voigtlander and Rayqual focus on infinity...
    daggerlee
    I'm using the Voigtlander M->m4/3 adapter, together with a Voigtlander LTM->M (28, 90mm) adapter. I'm using a Voigtlander 12mm. When everything's attached, the red dot on the Voigtlander M->m4/3 adapter lines up perfectly with the E-P1.
    The white dot on the 12mm is a little off center though - a little bit to the right of the red dot. Seems to focus to infinity, though.
    To those with Voigtlander adapters and using Voigtlander lenses - do your white dots line up with your red dots?
    OzRay
    I've got two Voitlander adapters, VM to m4/3s and Nikon F to m4/3s, and both are of excellent quality. The only thing that I don't like about the Voitlander adapters is that they don't come with proper end caps, just a cheap and nasty slip-on, soft-plastic cap.
    Now where can one find good lens and body caps for m4/3s?
    Cheers
    Ray
    daggerlee
    Agree about the cheap slip on caps. I gave my lens a harder turn today and it seemed to line up properly.
    I believe one of the eBay vendors (jinfinance maybe?) sells end caps.
    Apr 2009
    Vancouver, BC
    221
    Quote Originally Posted by JMaher View Post
    Jim
    I got mine for $1600HK, which works out today at about $207US. After comparing them (M and R) to the Voigtlander M adapter, I would have to say that the Panasonic ones are the nicest. They look very 'Leica-like' in all their details. Fit and finish are excellent.
    Henning
