Mike Hatam
Senior Subscriber Member
Tim - thanks for doing this testing. I'll be watching this closely, as the 50 lux is my main lens on the E-P1, and will want to know the optimal IS settings (depending on shutter speed).
Mike
Mike
You're doing that correctly Terry. I am sure it does refer to actual rather than equivalent focal length.Thanks Tim,
You are a dedicated tester! I do want to just double check one thing. When I am putting in the lens focal length I'm using the lens actual, not the m4/3 equivalent. So, I'm setting the 50 at 50 not 100.
The 50 lux is the lens I kept from my M8 sale . For some odd reason I like using it more on my Pen than G1.
Buddy, it's just that I'mHi Tim
Glad you bit the bullet - it's especially good to have you around here to do all the tests that the rest of us humble mortals are either
1. too busy
2. too lazy
3. too incompetent
to do (in my case I claim all three faults).
Stuart, the 50 lux I refer to in the previous post is the 1.4 and shot against the light on the Pen it has sometimes very bad CA, the cause of which is I think an imperfect marriage of camera and lens rather than the fault of either.have any of you tried an APO lens like the 75 summicron or even the 50/1.4 ASPH (which is supposed to be APO, though they did not bother to characterize it as such)? I am wondering how much of the CA is from the lens, and how much is from the internal characteristics of the Pen sensor glass and IR filter...I get the impression that much of the CA we see on digital cameras is a result of the sensor glass more than the lenses themselves.
Is that with the RayQual adapter? If it isn't, that could be the source of your problem.Stuart, the 50 lux I refer to in the previous post is the 1.4 and shot against the light on the Pen it has sometimes very bad CA, the cause of which is I think an imperfect marriage of camera and lens rather than the fault of either.
Under normal circumstances the lens gives lovely results on the Pen.
It's with the cameraquest adaptor which seems very well made. According to Sean Reid (and this makes sense) if you think about the microlenses that had to be put onto the edge sensors of the M8 to make M lenses work on it, and realise that the Micro 4/3rds do not have these micro lenses, then a change of adaptor is not likely to make any difference. I'd like to be proved wrong though!Is that with the RayQual adapter? If it isn't, that could be the source of your problem.
It's the ASPH, a retlatively recent and still very current lens that also happens to be the finest lens I've ever owned!Yes, I realize it is the 1.4, but is it the 1.4 ASPH or the 1.4 pre-ASPH? The pre-ASPH does have some CA even on Leicas and film, but the 50/1.4 ASPH should not really have any. But I do understand the point about the marriage of lens and sensor...sometimes it just does not work as well as it does when using native lenses.
Tim, In my experience, if there are shiny exposed metal parts in the optical path (as in an unpainted adapter or most Leica lenses with their RF coupling rings) then that causes problems and induce lateral chromatic aberration on the G1. Cameraquest adapter is the same as the RayQual, I think. That should be good.
Any other lens (apo or garden variety- almost all of them) do not show any CA.
To check this, take a lens that does not show CA and put a piece of aluminum foil in the optical path (rear of the lens). This would induce CA.
Not a matter of microlenses on the sensor at all, IME. I would check if there are rubbed metal parts in your Summilux.
