Results 1 to 5 of 5
Thread: AFocus...not the best?
    Senior Member Rawfa's Avatar
    Nov 2008
    Rio de Janeiro
    2,393
    I've noticed that many photos are getting out of focus with the autofocus, even at high shutter speeds. Is there any firmware update to fix this? My image stabilizer is set to off.
    Terry's Avatar
    New York City
    6,955
    1145
    Re: AFocus...not the best?
    Can you manually focus to know you don't have a lens problem?
    You don't by chance have a soft focus art filter on?
    Senior Subscriber Member Mike Hatam's Avatar
    Los Gatos, CA
    853
    236
    Quote Originally Posted by Rawfa View Post
    It might help if you mention what camera you are using.
    Mike Hatam
    Sony A99, RX1, RX100
    Nov 2008
    Rio de Janeiro
    2,393
    Oh, sorry. I'm using the E-P1. I'm not using any art filter and I am able to properly focus manually. Just in case I've set the image stabilizer on (I.S. 1).
    Los Gatos, CA
    853
    236
    OK, there is no recent firmware for the EP-1 that I know of, beyond version 1.0.
    You might try with a tripod, to eliminate the variable of camera movement, to see if that's causing the problem. Also, try setting your focus point to just the center point/box, and focus on a particular item, and see how that works.
    Are you having this problem with all lenses, or just a single lens? If it's just a single lens, it might be a faulty lens.
    Mike Hatam
