Results 1 to 22 of 22
Thread: E-P1 Dynamic range
    Senior Member Rawfa's Avatar
    Nov 2008
    Rio de Janeiro
    2,393
    E-P1 Dynamic range
    Is it me or isn't the dynamic range on the E-P1 that great? I have to say that compared to the DP1 I'm finding a BIG difference. The detail and dynamic range on the DP1 is just phenomenal and I thought that was what I was going to get with the E-P1...sadly it doesn't seem so.
    Senior Subscriber Member Mike Hatam's Avatar
    Los Gatos, CA
    853
    236
    Re: E-P1 Dynamic range
    I haven't compared to the DP1, but isn't that one of those special 3-layer sensors for true color? Lower resolution, higher color accuracy and dynamic range. Probably not an apples-to-apples comparison.
    The E-P1 has better dynamic range that I saw on my E-420, and at least as good (maybe a touch better) than I had on my G1.
    But I'm still waiting for good raw processors (LR/CS) to support the E-P1, so I can see how much headroom I have in the highlights, and how much I can mash the bits around without ruining the file.
    Mike Hatam
    Sony A99, RX1, RX100
    Nov 2008
    Rio de Janeiro
    2,393
    That's another thing, with the DP1 you could really pound it's jpgs hard on post and they wouldn't fall apart. I'm also still waiting for RAW support for Photoshop to see how it goes.
    Subscriber Member tashley's Avatar
    Jan 2008
    South of England
    3,295
    Quote Originally Posted by Rawfa View Post
    I disagree profoundly.
    DP1 files look astonishing first up on screen: silky, gorgeous, almost better than real. As native sized images they also take quite a lot of processing and in many situations they upres well: I had a show last year where I exhibited 20 x 30 inch shots, some from an M8 and some from a Canon 1DSIII but I snuck in one from the DP1 and not only did no one comment on any perceived quality difference but it turned out to be one of the best sellers of the edition.
    But the DP1 is now my glovebox camera: too good to sell on eBay but not good enough to be my main 'small carry around'. The reason is what it does to any regular round shapes (balls, arches on buildings etc) when upresed to the files size dimensions it lays claims to. All those curves go 'aliased jaggy' and it shows in prints, starting in some cases not far above A4.
    Also anything above ISO 200 has weird colours for reasons we all know and PP to try to correct this can force you into other corners.
    This week's amateur photographer mag in the UK found what I find: that if you expose the Pen at it's natural ISO of 200 you get very satisfactory DR and furthermore, the camera's exposure system is so consistently good that you most often get every drop of that DR. Just make sure that you turn of the display boost option so that when you use exposure compensation for heavily backlit situations, the LCD does in fact let you see what you're doing!
    Best
    Tim
    May 2009
    Barcelona/Catalunya
    33
    we discuss this in the german DSLR-Forum as well. OOC, the DP1/DP2 is unreachable for the E-P1, but if you develop RAW-Files, even with the Kit-Lens(remember DP1/2 are primes), the results are slightly better, so take a closer look at the photos here:
    http://www.dslr-forum.de/showpost.ph...&postcount=581
    In the moment i use C1 with the hack(Profile of the E-30), but i think we have to wait for the correct profile for the E-P1 before final conclusion about the IQ.
    Yogi
    Terry's Avatar
    New York City
    6,955
    1145
    Can't see the picture you refer to. I think you need to be logged on as a member
    Senior Member Brian Mosley's Avatar
    Jan 2008
    2,394
    17
    I think it's you
    The E-P1 has excellent dynamic range imho.
    E-P1 + 17mm f2.8 pancake
    1/100s f/2.8 at 17.0mm iso200
    I have the DP1 too... nothing special compared to the E-P1.
    Kind Regards
    Brian
    May 2009
    Barcelona/Catalunya
    33
    sorry, but now:
    Attachment 19556
    Yogi
    Nov 2008
    Rio de Janeiro
    2,393
    Quote Originally Posted by Brian Mosley View Post
    I think it's you
    Kind Regards
    Brian
    JPEGs wise I really don't see it. Like it was said before RAW maybe a different story. But I won't find that out until Photoshop puts out a RAW update for the E-P1 (I absolutely hate having to use different apps when one should be able to do everything).
    Nov 2008
    Rio de Janeiro
    2,393
    To be honest, after my experience with the E-P1 I decided to hold on to the DP1.
    Nov 2008
    Rio de Janeiro
    2,393
    Is there any in-camera filter or setting that could maybe increase the dynamic range? The first day I've got the camera I've tried one of those art filters called "pale" (I think that's how it's called) but it won't let you use the camera in manual mode. I don't know, maybe I'll simply try decreasing the contrast...
    Member bcaslis's Avatar
    Jul 2009
    Wilsonville, OR, USA
    39
    What settings did you use for the E-P1? It has best dynamic range at ISO 200. You will get reduced dynamic range at ISO 100.
    May 2009
    Barcelona/Catalunya
    33
    Quote Originally Posted by bcaslis View Post
    only in jpg, with raw you have the same dynamic range, don't know why
    Yogi
    Jul 2009
    39
    I would have to disagree with this. I've seen nothing including my own pictures that suggest RAW doesn't see a dynamic range drop when using ISO 100. The base ISO of the camera is 200. ISO 100 simply overexposes and then reduces the brightness. You don't lose DR in the shadows but you will lose it in the highlights for sure.
    Jan 2008
    South of England
    3,295
    You are 100% right.
    May 2009
    Barcelona/Catalunya
    33
    Quote Originally Posted by tashley View Post
    You are 100% right.
    yep, and i apologize i mix something up
    Yogi
    Senior Member Will's Avatar
    Near London
    1,054
    Quote Originally Posted by mod2001 View Post
    sorry, but now:
    Attachment 19556
    Yogi
    Which image is the DP1 or E-P1
    May 2009
    Barcelona/Catalunya
    33
    Quote Originally Posted by Will View Post
    both are E-P1, left JPG OOC, right RAW with adjustments
    Yogi
  19. #19
    Near London
    1,054
    Thanks.
    Quite a difference!
  20. #20
    May 2009
    Southport, Australia
    1,429
    Hi
    how can this be in RAW? If it is reducing brightness then it can not be raw, unless there is a different encoding strategy for the analog data from the sensor in different ISO settings.
    I have seen nothing to suggest this in my own camera (G1)
  21. #21
    Jul 2009
    39
    Reducing the brightness is probably the wrong term. The fact is that a number of cameras have a base ISO of 200. ISO 100 is simulated by overexposing the image (since you can't get lower than the base ISO) and then digitally lowering the output. This has the effect of preserving shadows but reducing the highlight range overall reducing the dynamic range.
  22. #22
    May 2009
    1,429
    sounds desirable to me ... rather like non-linear encoding strategys. Unless of course that one exceeds the signal to noise capacity of the shadow areas and essentially only gets dirtier shadows.
