Results 1 to 4 of 4
Thread: Potential Hyperfocal Workaround for EP1
    266
    Ideally, a future firmware update will give us a manual focus scale display. In the meantime, the following might work.
    Let's say one is working with the following,
    - the 17mm pancake lens
    - f/8
    - external optical viewfinder
    - wants to focus at 10ft
    Here is how the camera can be setup,
    - AEL/AFL button set to S-AF (no MF)
    - Lens reset to Off
    - Use AEL/AFL button to focus on something 10ft away
    - Turn off LCD
    This way, the camera should be very quick for "street shooting".
    Have you found a better way? If so, please share. Manual lens is, of course, another option.
    Subscriber Member Streetshooter's Avatar
    Jul 2008
    1,431
    17
    Re: Potential Hyperfocal Workaround for EP1
    So will this disconnect AF? Otherwise on release the
    camera will hunt.....
    I will try it later with the zoomie @ 28mm and the
    Voigtlander finder.....
    Don
    266
    With AF assigned to AEL/AFL, it appears to me that shutter lag is minimal. In other words, when the shutter button is fully pressed, the camera does not try to AF again.
    Terry's Avatar
    New York City
    6,955
    1145
    I'm doing the opposite. I have lens reset on so I know at startup I have infinity focus. Still there needs to be a better way for both Pen and G1
