Results 1 to 8 of 8
Thread: E-P1 iso 3200
    Senior Member Rawfa's Avatar
    Nov 2008
    Rio de Janeiro
    2,393
    E-P1 iso 3200
    I never, I mean NEVER shoot beyond iso 1600 unless it is absolutely 110% necessary. BUT I decided to test the E-P1's boundaries just for kicks:
    Kit lens at 25mm and ISO 3200 (please, don't bare in mind my mugshot face):
    Senior Member Per Ofverbeck's Avatar
    Feb 2008
    503
    5
    Re: E-P1 iso 3200
    Absolutely great! Lots of "film feeling", but mainly a very good portrait. Dramatic lighting well used, too.
    From your description, I assume its a self-portrait. Did you use a mirror, or did you just shoot "blindly"? The excellent cropping looks far to good to have been made without seeing what you were doing.
    Nov 2008
    Rio de Janeiro
    2,393
    Re: E-P1 iso 3200
    Thanks! Yes, it is a self portrait. This was actually the best out of 3 blind shots. And BTW, I used the in camera B&W with the in camera RED filter. I then brought it into photoshop and increased the contrast and crushed the shadows. It is actually pretty amazing to see that if necessary you can take iso this high with the E-P1.
    ddk
    Re: E-P1 iso 3200
    I'm a fan of high contrast, grainy shots and like your portrait Rafa! Try holding the eyes back a bit when compressing the blacks for more life.
    1,008
    Re: E-P1 iso 3200
    Quote Originally Posted by ddk View Post
    David, for my ongoing education in post processing, can you further explain "holding...back" and "compressing the blacks"?
    ddk
    Re: E-P1 iso 3200
    Quote Originally Posted by tom in mpls View Post
    Compressing the blacks is what Rafa has done, darkening the shadows and making them more black and loosing some detail as a consequence. In PS, one of the ways to do this is with levels adjustment, pulling the left triangle towards the center will accomplish this. One can also do a levels adjustment "layer", same control but on a new layer, hence the name, where one can control & apply the darkening process selectively with the layer mask, this way he could block the eyes from becoming so dark while the shadows would be as dark as he wants.
    Senior Member barjohn's Avatar
    Galveston, TX
    947
    171
    Re: E-P1 iso 3200
    I am amazed at how good the ISO 3200 files can be made to look. I turned off all noise reduction in camera. The following side by side images were taken a few seconds apart. The one on the left is at ISO 200 at 1/3 sec, f2.8 and 17mm. The one on the right was taken at ISO 3200 1/40 sec, f2.8-17mm. There is some camera blur in the first since these were both shot hand-held. Sitll, I think it is amazing how close they are. These were processed JPGs in BibblePro 5 Bete 2.2 using Noise Ninja on the ISO 3200 shot.
    V/r John
    Senior Member nostatic's Avatar
    Jan 2008
    socal
    1,037
    Re: E-P1 iso 3200
    Quote Originally Posted by Rawfa View Post
    This is what I've been alluding to in other threads - I really like the look of the high iso images from the EP1. It is not "clean" but I find the noise quite pleasing for certain applications. Much better than the noise I get with a small sensor and even the APS-C sensor (depending on the details).
