Results 1 to 8 of 8
Thread: Reading E-P1 RAW files in Aperture 2.1.4
    Senior Member barjohn's Avatar
    Galveston, TX
    947
    171
    This is tedious but simple. Perhaps someone could write a batch script to accomplish.
    This method fools the RAW converter into thinking the files are from an E-30.
    1. Make copies of the .ORF files you want to convert.
    2. Open each one, one-at-a-time with Text Edit. Scroll down until you see E-P1 and replace the P1 with 30
    3. Save the file and close it.
    4. Repeat for each image.
    You don't have to scroll down very far and you only have to replace it once. You can now import it into Aperture and edit the file.
    It would be cool if someone wrote a script that copied and converted in one operation on a range of files. Otherwise we will have to until Apple fixes this.
    V/r John
    Jun 2009
    Austria
    23
    7
    Re: Reading E-P1 RAW files in Aperture 2.1.4
    Hello John,
    in the underlying Unix there exists sed (stream editor). With
    sed -e '/E-P1/{s//E-30/;:a' -e '$!N;$!ba' -e '}' -i .org P1234567.ORF
    the first occurence of E-P1 in P1234567.ORF is changed to E-30.
    Because of the "-i .org" a copy of the original file is made as P1234567.ORF.org as well.
    you can create an automator workflow like that
    http://farm3.static.flickr.com/2480/...d51d1e3f_o.png
    regards
    johannes
    (Image is on Flickr - http://www.flickr.com/photos/johannesfleitner/ )
    Senior Member kevinparis's Avatar
    Jun 2008
    919
    5
    I have something half working... well it works on my machine just because i paid 15 euros for a Automator action that does the find and replace on a text edit file... but wont work on a machine without it.
    still it was a fun day.. can't believe Applescript makes doing search and replace so difficult or indeed doesn't let you take full control of TextEdit... on the otherhand it may just be my complete lack of understanding of programming.
    would be happy to share my workings on a absolutely no guarantee basis
    cheers
    K
    Jun 2009
    Austria
    23
    7
    Hello Kevin,
    if you have OS X, you should have sed, which can replace strings.
    I hacked a quick and dirty workflow - you select a folder and start the workflow.
    you can download the workflow from http://members.aon.at/johannesfleitn...0.workflow.zip
    regards
    johannes
    Jun 2008
    919
    5
    gio... tried to download workflow... but seems to be damaged... e-mail me it at [email protected]
    cheers
    Senior Member Robert Campbell's Avatar
    Norn Iron
    1,097
    Is it too simplistic to suggest converting to dng?
    Sláinte
    Robert.
    Galveston, TX
    947
    171
    I can tell you from trying both that the results are different between the conversion created by fooling Aperture and the Adobe DNG conversion. Which one you prefer will be a matter of preference. My wife liked one batter and I liked the other better. Also, when there is a modified ORF and a JPG of the same shot, you can load an image of the JPG. With just a converted DNG and JPG of the same shot in the folder you can not bring up the JPG.
    V/r John
    Jun 2008
    919
    5
    i persevered with my learning of Applescript and now have a working little app that you drag a bunch of e-p1 raw files to and it makes a copy and uses Textedit to do a find and replace. Aperture now thinks that the files came from an E-30
    Anybody wanting to try it out drop me an email
    [email protected]
    cheers
    Kevin
