Results 1 to 22 of 22
Thread: Best hasselblad V system lens
    80
    I'm just starting to build out my V system mainly for portraiture and landscape use, can everyone share there view to the best three lens?
    80
    Re: Best hasselblad V system lens
    Should add this is on the 501CM and looking to get a 503CX or CW.....
    Mar 2009
    119
    80 CF/e 50 CF or the CFi (if you have the budget) and lastly, the 180mm CF. the 120CFi's also quite well known for portraiture, though a tad slow at F4.
    Senior Member JimCollum's Avatar
    santa cruz, ca
    936
    155
    i've been extremely happy with the 3 that I use.. 50/2.8, 80/2.8 & 110/2 (probably one of the best portrait lenses ever made)
    Los Altos, CA
    10,486
    1031
    Jim, will the F lenses work on the V body? I know the V lenses work on the F body, but I didn't think they worked the other way around...
    home: www.getdpi.com
    80
    Hi All,
    I have a few options and am seeking advice. I have an 80 CB & 150 CF Len for my 501. What to add next as budget is tight:
    1. 160 CB lens
    2. 120 CFI lens
    3. 150 CFI lens
    4. 120 CFI lens
    My goal is mainly portraiture and the 160 CB is half the price of the others!
    80
    Or dobi hunt for a Cf 180 as that is around the same vas well but thought this might be a little too long!
    40
    They do not, V bodies require leaf shutters, which the F lenses lack.
    Aug 2010
    Maryland
    475
    Lightbulb Re: Best hasselblad V system lens
    Quote Originally Posted by hobbsr View Post
    There's no getting around the fact that price and quality go hand-in-hand.
    - Leigh
    Dec 2009
    39
    If I already had the 150/4 (which I have, by the way ;-) ), I won´t go for the 160/4,8, because these focal lenghts are too close to each other. The 180/4 is a stunning performer but is relatively large and heavy compared to the other lenses you mentioned. I also find hand holding the 150/4 quite difficult at times, might be even harder with the 180mm. I really prefer the old S-Planar 120/5,6, because it has great performance and is considerably light weight. Only problem is that it is quite old so you might get the shutter serviced, and the screen becomes relatively dim because of the f5,6.
    For landscape I recommend the 50/4. It is compact, light weight and can be had for little money today. I cannot comment on the 40/4 but it is obviously a great lens (and is the next on my wish-list).
    Best, Benjamin
    Brooklyn
    4,043
    1253
    I have this V or F system lens for sale:
    40mm CFE IF Distagon, with box, bag; this lens is absolutely perfect and a perfect optical sample: $4,500
    CFE lenses work with F and V cameras
    FE lenses work only with F
    C lenses work with F and V, but without electrical connections to F body
    Jul 2010
    44
    I think the 80mm f2.8 is still the best all rounder so far Great for most things.
    Not Available
    Jul 2009
    New York
    1,864
    Some say the 60/100/180 combo is the newer, better choice. Me, I went with the "more traditional" 50/80/150 trio for various reasons. Honestly, none of them are duds.
    The 2,8/80 Planar is a must have, if nothing else than for the f/2.8 aperture - and it's cheap and plentiful.
    Feb 2009
    1,083
    6
    I don't have 80mm not even 50, or 120, all what i have are 60mm and 150mm.
    Tareq
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,933
    My Hassy kit was the 903SWC with Biogon 38/4.5, the 500CM with Planar T* 80 and Sonnar T* 150. Best, worst ... I don't know. They're what I had and used, and they worked very well. :-)
    A friend has them now and he still loves using them.
    carstenw's Avatar
    Berlin, Germany
    2,530
    50/2.8, 110/2, 250/4, all FE
    Carsten - Website
    tetsrfun
    Interesting question of what exactly is the "V" series Hasselblad. I can't find a definition but I think of the "V" series as all post 1957 'blads as many of the modular components are interchangeable. I have about a dozen Zeiss CF, F, FE lenses. For 500 series bodies, the 50 and 180 CF are probably most used. The 40mm is perhaps a better lens but costs a lot more than a 50. For 200 series bodies, 50mm 2.8 and 110 F/2 are most used followed by the 150 and the 250. The 110 F/2 FE is probably the best lens that I have, including about 6 "pro" Nikons.
    Steve
    Nov 2010
    622
    5
    Where can I buy a V system with Digital back? thank you rollsman
    my email is : [email protected]
  19. #19
    Aug 2010
    Maryland
    475
    Quote Originally Posted by tetsrfun View Post
    Hi Steve,
    The V series is the 500-series and associated lenses and accessories. It probably also includes the focal-plane cameras, since they can use the same lenses as the 500s (as well as the F lenses).
    The V designation only came into use when Hasselblad brought out its newer H series, since the lenses are not interchangeable between the two.
    - Leigh
  20. #20
    Aug 2010
    Maryland
    475
    Quote Originally Posted by rollsman44 View Post
    Probably the largest selection would be on evilpay (ebay.com).
    You might consider buying the camera body and the digital back separately. I bought a CFV-39 back through the local Hasselblad dealer, and bought a used 555ELD body to go with it. Works fine.
    - Leigh
  21. #21
    tetsrfun
    I didn't appreciate the the "V" designation came into use with the introduction of the "H". So I guess 'blads are "V", X-Pan or "H".
    "Probably the largest selection would be on evilpay (ebay.com)."
    KEH.com also....probably the safest place to buy if you are unfamiliar with Hasselblad pricing. Very few "great deals" on Hasselblad on ebay careful watching and waiting can save a few hundred $$$ but there is a lot of junk being sold.
    Steve
  22. #22
    Time
    My lens line ups are simple but effective for all my purposes. For film and digital capture I use the leaf shutter lens (3.5/60, 2.8/80, 4.0/120, and 4.0/180). They render very beautiful images in film and in digital sensor. I recently bought the 555ELD from ebay which I always wanted one but was not able to afford it until now. The camera works nicely with all the lens I own. For film capture only I use and prefer faster lens (2.8/50, 2.0/110, 2.8/150, 4.0/250, 4.0/350) with my 202FA camera.
