Results 1 to 5 of 5
Thread: Which hasselblad camera
    80
    Hi all,
    Just following on regarding best lens. I want to see what people think is the best V camera. I already have a 501 and have the option to buy one of the following:
    1. 503cxi mint
    2. 501cm mint
    3. 503cw
    The 503cxi is the cheapest option and the 501 the highest but does come with the 80 CB lens the others are bodies with WLF.
    I know the 503cxi does notbhave the newer glide system and therefore will have a slight vignettevon 120 mm lens and above? Otherwise not sure what if any othervadvantages the other models hold. I don't care about flash ttl just want the best build quality!
    Feb 2009
    1,083
    6
    Re: Which hasselblad camera
    3. 503CW
    2. 501CM [which i have and happy with it]
    Tareq
    Jan 2009
    Baltimore, Maryland USA
    466
    I wish I knew what all of this meant because I really want a Hasselblad bad! The only thing I know of is the 500 CM though, so I hope to learn something from the experts here.
    Feb 2009
    1,083
    6
    Quote Originally Posted by Scott G View Post
    You can't go wrong with any Hasselblad, go with 500CM or 501CM and never look back, 503CW is almost the same with TTL and gliding mirror features i think, so it is up to you, i am still happy with Hasselblad 501CM, amazing results i have get out of it.
    Tareq
    Mar 2009
    Reunion Island, Indian Ocean
    293
    49
    I own a 501cm wich I bought with the CB80M. It is a great camera, and the market of second hand lenses is huge and affordable ; beware of the quality of what you are going to buy because reaprations and CLA (Clean, Lubricate Adjust) are really expensive.
    The only difference as said above betzeen 501cm and 503CW is the TTL : if you don't shoot flash, go for a 501cm...
    http://stef974.tumblr.com/
