Results 1 to 24 of 24
Thread: Chemical question
    Sep 2010
    Philly area, PA, US
    354
    Chemical question
    I am just starting doing film development (B&W). I ordered Ilford fixer
    http://www.bhphotovideo.com/c/search...tialSearch=yes
    It just arrived today and when I looked at the instructions for dilution and times, it only mentions paper development, not film.
    On B&H site, it says that's for both. Why wouldn't be info for film in there if it is for film and what dilution and times should I use?
    Thanks for any advice.
    Dec 2009
    Culver City, Ca.
    167
    Re: Chemical question
    According to this: http://www.darkroom.ru/info/manuals/...manual_eng.pdf
    It looks like you should be fixing your film for 2-5 minutes with a 1:4 dilution. If you didn't also order hardener, you might want that for your film as well. It really helps to harden the emulsion and prevent subsequent scratches, but you generally don't want hardener in fixer for prints, as it greatly increases washing times an can have a detrimental effect on toning.
    Sep 2010
    Philly area, PA, US
    354
    Quote Originally Posted by pfigen View Post
    It looks like you should be fixing your film for 2-5 minutes with a 1:4 dilution. If you didn't also order hardener, you might want that for your film as well....
    Thanks Peter. Although the suggested times are 2 or more than double the time
    This is my first time developing film so I don't have any experience with it. The post with the Caffenol got me interested and I will give it a shot.
    I wasn't sure if I got the right fixer since on it there is no reference to film whatsoever. We'll see how it comes out
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    The rule of thumb is that you fix film for twice the clearing time.
    Look at a the film and if it appears a bit cloudy, then put it back in the fixer. When it just clears, then double that time.
    -bob
    Sep 2010
    Philly area, PA, US
    354
    Quote Originally Posted by Bob View Post
    -bob
    Bob,
    So, let's say I let it fix for 3 minutes. Take the film out (no washing) and look at it and if cloudy, put it back in for let's say another 30 seconds. After the 30 seconds it looks good so the normal time would be 7 min?
    Prescott, Arizona
    4,492
    367
    Quote Originally Posted by Valentin View Post
    Bob,
    That is correct.
    -bob
    Sep 2010
    Philly area, PA, US
    354
    That is correct.
    -bob
    Thanks.
    Oct 2008
    141
    Better yet, clip off a bit of the leader and drop it in a cup of the fixer in light. Then you can determine the clearing time without removing your reel every couple minutes.
    In general though, I use Ilford Rapid Fixer at 1:4 for about 4 mins. I don't use hardener.
    tokengirl
    Quote Originally Posted by Tim Gray View Post
    Pretty much the same for me.
    Sep 2010
    Philly area, PA, US
    354
    Thank Tim and Tokengirl (what's your name ).
    I guess I will shoot a couple of rolls at the same values and try different times to see which one is better. It's not like it's going to break the bank (especially if you compare with the digi backs ).
    I can't wait to get the damn materials. It takes a week for stuff to get from Montana to PA and only 3 days to get albums from Italy to PA
    Oct 2008
    141
    Where are you in Philly? I'm near the airport...
    Sep 2010
    Philly area, PA, US
    354
    I'm outside Philly: Blue Bell. Plymouth Meeting area. We should get together sometime.
    Senior Member mathomas's Avatar
    Dec 2009
    1,148
    I use Rapid Fix for 5 minutes. Didn't ever test it. Never a problem (that I can see).
    Sep 2010
    Philly area, PA, US
    354
    Quote Originally Posted by mathomas View Post
    Thanks Mike.
    Oct 2008
    141
    Definitely. Right up 476. I'm at exit 3.
    Sep 2010
    Philly area, PA, US
    354
    Dumb question: how do you clean your stuff? Do you just rinse with water or do you use soap? (as I'm processing my very first film; finger crossed).
    tokengirl
    What stuff? You mean your tank and reels?
    I put mine in the dishwasher. But I am using the stainless tank and reels. I don't know if I would do it with the plastic stuff.
    Sep 2010
    Philly area, PA, US
    354
    Quote Originally Posted by tokengirl View Post
    Yes, the graduates, tank and reels. I have the plastic one (it was the only one that came with the agitator; the stainless steel ones didn't).
    I only "cleaned" it with warm water. I don't know if I'm courageous enough to put it in the dishwasher due the chemicals.
    My first ever development was a success. I'll post pictures when I scan them.
    Thanks.
  19. #19
    Prescott, Arizona
    4,492
    367
    Usually a rinse with warm water is all that is needed.
    There are very few processing chemicals that require a detergent notably some color processes.
    -bob
  20. #20
    Sep 2010
    Philly area, PA, US
    354
    -bob
    Thanks Bob. The only real darkroom chemical was the fixer. I used the Caffenol method that Carl mentioned:
    http://forum.getdpi.com/forum/showthread.php?t=21881
  21. #21
    Dec 2009
    1,148
    After the negs are hung I fill the sink with pure-hot water and stir the dev equipment around with my hand (ouch). Then I empty and refill with less-hot water and stir around more. Then I empty the sink and run water over the bits and place them on folded paper towels to dry. In order to avoid dust, I don't leave them out too terribly long (only overnight, in Denver, CO).
  22. #22
    Sep 2010
    Philly area, PA, US
    354
    What can I say: I LOVE IT. Here is one image from my very first film developed.
  23. #23
    Oct 2008
    141
    Looks good!
  24. #24
    Sep 2010
    Philly area, PA, US
    354
    Looks good!
    Thanks. It looks better than I expected
    When I first took it out of the tank and I saw there is something on it (and looked OK), I was like a kid in a candy store.
    Also, I really like the tint that comes out of it.
