Results 1 to 3 of 3
Thread: Yellow tinge toward center of negative
    Sep 2009
    Irvine, CA
    132
    So, I've been processing BW (Neopan 400) for a couple of months now. Today, I did two rolls and upon drying, I noticed a yellow tinge running down the center of the roll. The edges, appear to be the normal color but this is the first time this has happened to me. I'm still new to this and would appreciate some thoughts on what may have caused this. The exposure seems normal and scans seems okay but I must have done something wrong during the process and this does not seem normal. I'm using Tmax developer and nearing the end of the container. Could developer be old? I've had it about 3 mos.
    Aug 2008
    Ontario, Canada
    96
    Re: Yellow tinge toward center of negative
    Your fixer is probably exhausted. You need to mix up a new batch and re-fix the film before the stain becomes permanent. You may have to do this in a tray if the film has already been cut.
    Sep 2009
    Irvine, CA
    132
    Thank you Bernard! That was it. Within a few minutes of soaking, the tinge disappeared. I failed to check my Fixer before using. Thanks again. Harv
