Results 1 to 15 of 15
Thread: yellow flowers on tree HELP
    Jamesmd
    Yesterday and today I went out to take some photos of trees , and no way I just don't get them right , tried different lenses , different aperture , and its like there was never focus .
    I know I'm not an expert , but I should be able just getting focus right
    is there something about yellow ?
    tomorrow I'll try again
    Cheers
    James
    4,333
    Re: yellow flowers on tree HELP
    James, I’ve a couple questions for you; what lens were you using? Did you try auto or manual focus and finally what was your f/stop? I should also ask how windy was it? I’ve always found shooting subjects like this very difficult.
    Don
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
    Jamesmd
    Hi Don , thanks for reply
    I went today again and looks better, but its like impossible to get the fluffy flours in focus .
    this is a CZ 85 1.4 . I used AF . And F quite small this time for blurred background , but I did go further away this time so I think DOF was ok this time , and , there was no wind today , and , I shot iso 200 this time for faster shutter.
    But still don't get the fluffy ones right , thinking of tripod next time , or I might be useless , that could be to .
    here they are .
    thanks Don.
    Los Altos, CA
    10,486
    1031
    Hard to say exactly, but when I look at the crops, it appears you are perhaps backfocusing slightly?
    home: www.getdpi.com
    Jamesmd
    at least I got one I like ,
    but not a flower
    Los Altos, CA
    10,486
    1031
    And further away from the camera -- where backfocus is not as much of an issue
    Jamesmd
    Hi Jack ,I'll test the lens .
    but look these I took today and are fine , well I think they are.
    both are 85 wide open , 1.4
    The man is Buero Vallejo.
    thamks
    Jamesmd
    Jack , could it be flare ?
    their so yellow , and like lots of little hairs , you know what I mean ?
    Jamesmd
    how do I test properly ?
    Jamesmd
    By the way , when are we having workshops in Madrid !!??
    Nice jamon, nice rioja , nice lots of things ,
    Los Altos, CA
    10,486
    1031
    Hi James:
    I may be in Madrid mid July to check it out as a possible stop for a future "Grand European" workshop Guy and I are working on
    Anyway, my point is that focus error can occur with change in distance -- so the 85 may be spot on at say 3 meters, but then off at 1 meter. And it can also change (significantly) with aperture! To test, I simply drop a coin on a well lit carpet and shoot the coin at about a 45 degree angle from various distances and apertures -- usually wide open through 11 in whole stops and 1 and 2 meters distance. Then at 100% it's easy to see where the carpet fibers are crisp and where the resolution falls apart.
    Jamesmd
    thanks ,
    It must be a stop , lovely little villages around .If you come , tell me I'll invite you to a beer o 2 in some nice taberna .
    Los Altos, CA
    10,486
    1031
    Will do!
    Wisconsin
    3,581
    118
    My advice (after you check the backfocus issue per Jack's instruction) is to use a tripod and manual focus. If you are shooting wide open (or near), you will need to place focus precisely. Also, make sure it isn't windy. Wind is a deal killer when shooting little flowers like that.
    Jamesmd
    thanks Cindy. Yes , I should . you always think , bah , I don't need to cary the tripod , but ..
    cheers
